11-22-2008, 01:25 PM | #1 |
head light knob
72 chevy truck
How does the headlight knob come off I am taking dash off to clean and paint and can't figure out how to get the know off. I don't want to brake it. |
11-22-2008, 01:30 PM | #2 |
Re: head light knob
reach behind it (that means stick your arm way up behind the dash), there's a tiny round button thing with a spring on it, it'll be on the top of the switch. push that in while pulling in and out out the knob and the whole rod comes out.
11-22-2008, 01:40 PM | #3 |
Old member
Re: head light knob
You need to take the battery loose or take the wiring off the backside of the switch before doing this. If not the lights will stay on the whole time.
11-22-2008, 01:52 PM | #4 |
Between Trucks...
Re: head light knob
I found if you pull the knob out, then press the button on top it'll come out the rest of the way a lot easier.
Beat it to fit, Paint it to match... |
11-22-2008, 02:02 PM | #5 |
Re: head light knob
Thanks, I did not want to brake it!!
11-22-2008, 02:33 PM | #6 |
"THE GREEN GOBLIN"
Re: head light knob
Haha I wish I've known this before I was fighting with mine I forced it off and after it came out I noticed it didn't look like it was supose to come off without the rodthe rod
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
11-22-2008, 06:30 PM | #7 |
Re: head light knob
Andy: FYI. save your self 2 steps and leave the battery hooked up. use a screw driver about the same shaft size as the head light shaft and push the screwdriver in the hole till the lights shut off and remove the screwdriver. when your ready to go push in the light nobe all the way in and pull it out as normal for the lights to work . thats what i do.
Trueman Last edited by 463; 11-22-2008 at 06:31 PM. |
11-22-2008, 07:54 PM | #8 |
Re: head light knob
That may just be the trick of the day 463. The only thing is that when most of us need to pull the knob out of the switch we also need to change the switch and it is a bit safer with the battery disconnected.
