Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-22-2008, 06:31 PM   #1
blazer2007
do I need floating leafs with 3 or 4 link
I was wondering if I need to have the leaf springs on a floating u-bolt setup with a 3 or 4 link traction bar setup.I used to have one looooooong time ago on a camero on the track but is this setup still used,and the truck I,m going to use is mostly street,still need to hook up thou
blazer2007 is offline   Reply With Quote
Old 11-22-2008, 08:22 PM   #2
Super73
Super73's Avatar
Re: do I need floating leafs with 3 or 4 link
I'm not too sure I under stand what you mean here.. A lot of guys are running Caltrak Bars with Leafs. From what I understand on your set up you are:
Wanting it low
Wanting air bags to raise it and lower it
Want optimal traction
IMO from a tunability stand point go to the junk yard and find yourself a 1960-1972 pick up. Pull the trailing arm set up out of it. Cross member, arms, rear, panhard bar, springs and get it in your truck. Or buy a 4-link or ladder bar set up.
Trying to use a very soft leaf with air bags for ride height control may impact hooking the truck. The air bag is going to want to keep the truck at a specific ride height you have it set to and is not going to allow the rear suspension to either seperate or squat properley for drag racing.
This brings me to ask what are you planing for the front?
It's not easy to have some things that will hook hard yet have all the cool features. There are comprimises.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-22-2008, 10:44 PM   #3
ripdog28
ripdog28's Avatar
Leaf springs and a 3-4 link is odd. I have never seen that set up. 3-4 link= coils/coilovers. Leaf springs are your point of load from the axle to the frame. 3-4 link is your point of load from the axle to the frame. I am confused as to why you would not just do one or the other.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 11-23-2008, 11:09 AM   #4
blazer2007
I already have bags in the frontof the truck.the rear end setup I had in my camero was the rearend was free floating on the leafs,it could spin or slide forwards and back and the 3 link kept the rear in place,I guess back then it would have been a poormans coil over
Old 11-23-2008, 10:32 PM   #5
71Dragtruck
71Dragtruck's Avatar
I know what your talking about, lot's of Mopar guys ran ladder bar setups with floating rears in thier leaf spring cars. So ya no reason you cant do the same, and yes if you don't float the rear end it will bind on you.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-25-2008, 11:58 AM   #6
Super73
Super73's Avatar
I see.. So the leaf is used instead of the coil. Makes sens. I could see a bind issue if it wasn't free floating of the leafs.
But at that point, why not go coil over and mount your bag directly on the the axle behind the bag? You could fab up a quick piece to do both and weld it to the axle. A pad for the bag on top and a eyelet for the coil overs behind it.
