posi id?
is there any way to tell if there a truck has a posi rear end by the vin? on the dash it says heavy duty rear 307 but thats it
2009 dodge hemi custom paint 86 lwb bagged layin frame 73 2 door nova 54 bel air |
Re: posi id?
it would have option g80 on the glove box sticker, or look on the fill plug for a plastic tag. only other way is to pull the cover
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
Re: posi id?
My suburban has a sticker where the spare tire goes saying that the vehicle is equiped with a power lock ("posi track") rear end. Not sure where that sticker would be on a truck but I am sure it has one. Also my SPID specifically states that the truck came with the optional power lock rear end. Also I noticed a metal tag that is bolted to the rear end on the pumpkin that also identifies it as a posi.
Re: posi id?
THe truck that I took my posi from said it on the glovebox sticker and it had a red plastic tag on the diff oil filler say "limited-slip additive" or something...
edit, and if you step on the long pedal real hard you will leave two black marks on the road... ![]()
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 11-22-2008 at 08:43 PM. |
Re: posi id?
it might have a G86 no spin rear axle or a G87 power locker, the G80 code is the positraction rear axle codes found on the glove box door.
Trueman |
Re: posi id?
It may still have the metal tag attached to one of the bolts on the differential cover that should show if it is a posi or limited slip along with the original gear ratio. Most of the time guys are pretty good about putting those back if they have the cover off.
My Carbon Footprint
Re: posi id?
just jack up the back end and spin the tires. If they both turn forward, you have a posi. If they turn opposite, you have a uni-fryer.
#8 | |
Re: posi id?
i think the easiest ways to check for a posi are jack it up and spin the wheels, both wheels will spin the same way if posi, otherwise just go burn some rubber
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
Re: posi id?
well its already in in the air and if i push the gas pedal hard it would probaly got through the floor. i found it at a local yard its 69 cst
Re: posi id?
The filler plug on a posi is different as well. I will take some pictures for you of tag (red tag on filler is gone, but metal tag on cover still in place) and plug this afternoon if you will post pictures. Thanks Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
