Old 11-22-2008, 09:04 PM   #1
pilotj
I need leaf spring help
I was gonna post this in the suspension forum, but it looks like all thats talked about in there anymore is bagging and lowering. I need to know which leaves to remove for a smoother ride! My old spring pack had 8 leaves plus the thick overload and my new spring pack has 9 plus the overload. My old set had 3 broken on one side and 2 leaves broken on the other side (both main springs were broken at the center bolt hole). I only found it when I went to replace the bushings. I got a really good deal on the 9 leaf spring pack, but after a being beat to death for the past year, I can't take it any more. Two of the springs have got to go!! I still haul some wood and cars occasionally with it so I don't want to remove the wrong leaves. I just want a smoother ride. A local spring guy said the 2nd from the top and the 4th. Is that right? (he seemed kind of confused at the time). Its a '79 C20. Pic' are of the old and new set. Thanks
1979 Chevy C20 350/TH400
1974 Chevy C30 350/4speed
pilotj is offline   Reply With Quote
Old 11-23-2008, 12:44 AM   #2
Green77c10
Green77c10's Avatar
Re: I need leaf spring help
I called a local spring shop. they told me which ones and also told me if you invert the bottom leaf that makes a big difference as well.
Green77c10 is offline   Reply With Quote
Old 11-23-2008, 01:02 AM   #3
Square84
I don't think these pills work
Square84's Avatar
what kinda difference does it make the ride softer or firmer?
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 11-23-2008, 01:28 PM   #4
Green77c10
Green77c10's Avatar
I guess which leafs you take out affects the general performance of the spring, so it might affect load carrying and the smoothness of the ride. The shop did tell me to take specific ones out to get the best results for what I was looking for. The info was free, I just told them what the springs were for and how many leafs were on it and they told me which ones, about a 5 minute phone call.
Old 11-23-2008, 02:04 PM   #5
Duro5341
Duro5341's Avatar
Personally I would go and get the proper spring pack.....just get a 1/2 ton set with 3 and 1 overload. This will soften the ride, and you can still carry 1000lbs legally. As soon as you start modifying spring packs you are asking for a hole heep of problems. These springs are designed to work in a pack. i would start from the bottom and work your way up....leaving the overload. This is what is done in the factory spring packs....
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 11-23-2008, 06:21 PM   #6
Pyrotechnic
Pyrotechnic's Avatar
One issue with removing leafs if that if you start out with two spring packs that are equal and you remove identical leafs on each one, your end result may not be equal. It just depends on the leaf packs. Sometimes you get lucky and they turn out equal for the most part. Sometimes you end up with your truck leaning to one side. Kind of a gamble.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-23-2008, 11:06 PM   #7
Square84
Square84's Avatar
no sorry i mean what diff does inverting the overload make?
SQUARE84
90 SUBURBAN
Old 11-23-2008, 11:28 PM   #8
pilotj
Geen77c10, I was wondering what inverting the overload spring would do also. And you didn't say what spring leaves he told you to take out or the info he gave you. I'm asking here because I've gotten different answers from my spring shops around here. I was hopeing to find someone on this board that has removed them for the ride. I saw a post on here a while back about it but have searched for it and can't be found. Thanks to everyone for helping me out. It's a lot of work to do it it by trial and error, but it might be my best shot.
Old 11-24-2008, 04:25 PM   #9
Green77c10
Green77c10's Avatar
as you can see if you look at the overload, it has a very subtle curve, not much though. The shop also told me that it is not only an overload, but it is also designed to help control the spring and keep the leafs in line as well, i think they actually called it a control spring. What exactly they said I dont remember. anyway, they said that with it inverted, you are basically making it so that it takes more weight in the bed of the truck to compress the spring pack enough to where the overload comes into effect. I actually decided to let them do it for me, so i brought just the springs down to them. They unpacked, removed leafs, repacked, and made me a full new set of u bolts for $100, and only took them about an hour. The end result is a much smoother right (because of the no overload), but a spring that still performs as well as stock configuration. It was an 8 pack that was on my half ton, and 2 were removed and it actually lowered the rearend almost 2 inches, and it drives amazing for still having 6 leafs.
Thats just my story on the subject.
Old 11-24-2008, 04:29 PM   #10
Green77c10
Green77c10's Avatar
On my springs they took out the third and fifth leaf, out of the original 8.
Old 11-24-2008, 11:52 PM   #11
Square84
Square84's Avatar
so they did remove the overload and it dropped it?
SQUARE84
90 SUBURBAN
Old 11-25-2008, 01:28 PM   #12
Green77c10
Green77c10's Avatar
all they did was flip it over
Old 11-25-2008, 06:47 PM   #13
Square84
Square84's Avatar
ok thanks
SQUARE84
90 SUBURBAN
Old 11-27-2008, 12:07 AM   #14
pilotj
Is that the third and fifth leaf from the top? Thanks for all the great info.
Old 11-27-2008, 09:37 PM   #15
Green77c10
Green77c10's Avatar
yea, from the top. no prob! hope it helps. might be a bit different on that bigger spring pack, hope it gives some idea though
