Grandpa in the rustmobile...
Rusted floorboards..
Okay, i looked at my floor on both sides of my truck this afternoon..and i have some rusty spots....
1-both sides of the truck..on the floor under where the bottom of the door would be..the 'treadboards' maybe...I have a chrome plates that u step on commin in and out of the truck covering that rust up but would still like to get it fixed close/cheapest as possible 2-where your heal hits the floor when pushing the gas pedel..just a lil here 3-right below the highbeam floor switch..enough to put a few fingers in here..this is the main place im most worried about right now #2 #3 are patched with aluminum pieces wtih sheet metal screws holdin it down (I didnt do this someone else that had the truck before me did) but hows the easieest simplest way to fix this without takin the cab off...I can have it cut welded etc fairly easy..gfs dad can weld some ive gotta welder not too good yet and my buddys dad/grandpa can weld quite well...can probably have them do it next to nothing if nothing. what do i do? or should i leave it ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Rusted floorboards..
and im bout to have some pics of the cancer rust in my photobuket,,,if yall wonna look...and after i fix the floor properly ima install carpet ont he floor of the whole interior is that okay right?
ok on 1967 chevy i add pieces that i cut out from a diffenter truck
it was a 1969 chevy truck at the junkyard and used a air sander and whent down too new metal and what i know now if i know it before ive would have still have the 1968 chevy one ton truck |
#4 | |
1. the treadboards are called "Rockers" 2. DON'T leave it! FIX it!!! 3. you should be able to find pieces to fix it at a junk yard or in the classified section on this site. 4. lots of the replacement metal in catalogs like LMC Truck is thin and cheap
RN U OVR |
alritey hows this sound
get back to clean metal no rust...and fiberglass it over then carpet it later on? or should i still cut out weld new metal in palce and there called ROCKERS NOW lol thanks senator
