for you 4x4 guys on thanksgiving..
As you are feasting on a wonderful meal this Thanksgiving, imagine if
you will, you are only two inches tall traversing the Mini-Turkey Rubicon. As you winch yourself over the Mashed potatoes, you eye up a deep gravy crossing, thankful for the new bendable straw snorkel, you forge through the gravy with no problem, even the lumps are no match for your 0.33 Mud tires. Soon you see Turkey Back, one of the most difficult parts, crawling over the drumstick you carefully avoid the giblets (although you may go back later.) Now all that money in gears and lockers are worth it. Over the breast you climb all the way to the wishbone! You made it! but going back is even tougher. You choose an alternate route taking the wing for an off camber thrill. As you find yourself stuck in the stuffing, you pull out your trusty winch cable and bring yourself to the edge of the green been casserole. Remembering to tread lightly, you barely disturb the lush green vegetation pleasing the surrounding tree huggers. Finding your way across the table, you climb the rock pile of buns, you occasionally loose traction on the butter spills left behind by the carnage of less prepared and less skilled drivers. Suddenly snap! you too join the list of broken axles.Fortunately you find a toothpick and get yourself rolling again. Sadly you find that Pumpkin Pie is now closed due to Clinton land grabs so you head to the RTI Spatula to flex your suspension. Then you decide to skip cranberry hill and call it a day. i didnt write this, i copied it from a thread at CK5.com...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
