Old 11-23-2008, 11:01 AM   #1
JJanzen
JJanzen's Avatar
Heater Box Noise
When my thermostat opens after my truck warms up, you can hear the water circulating through the heater box. For about 30 seconds, it is very noisy like two squirrels scrambling to get out! Can anyone lend some insight to what is happening and how to fix? Thanks.
Joel
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 11-23-2008, 11:57 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Heater Box Noise
you might need a little more water in your radiator. Have you chacked the level after the themostat opens?
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 11-23-2008, 12:56 PM   #3
mrein3
mrein3's Avatar
What Bus Ted Knuckle is saying is you may be low on coolant. To get the right amount of coolant in the system you need to "burp" the system.
With the engine cold, take the cap off the radiator, put a catch pan under the open end of the radiator and start the truck. Let the engine warm up. Once you see a good, continuous flow coming through the radiator, fill it up to the top and replace the cap.
I suspect the noise you are hearing is a slug of air that is trapped in the system. Burping it should make the noise go away.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-23-2008, 01:20 PM   #4
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Joel
Have you checked the box for squirrels???
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 11-23-2008, 01:23 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Joel
The way you describe it, sounds like a little more than water or air circulating in the system. I've heard the noise squirrels make when they're in a cage or trap.. Loud!
Is this with the fan off and only after it warms up?
Also, does it make the noise without opening up the heater/fan control lever?
Could be a loose squirrel cage, motor, heat control valve, restriction in the heater or the mounting is loose.
68gmsee is offline   Reply With Quote
Old 11-23-2008, 01:27 PM   #6
JJanzen
JJanzen's Avatar
Thanks everyone for the immediate comments. It sounds a lot like a trapped air bubble. I am going to try and "burp" the system and see if that gets rid of it. I will let you know how it goes. Thanks again for the help.
Blue72
Red72
Old 11-24-2008, 08:17 PM   #7
JJanzen
JJanzen's Avatar
Thank you all for advise. A little additional water did the trick and the "squirrels" are now gone!
Blue72
Red72
Old 11-24-2008, 08:36 PM   #8
Bus Ted Knuckle
Son of a gun
you have enough antifreeze in the mix to do the trick don't you?
BEATERS ARE NEATER
