Old 11-23-2008, 11:19 AM   #1
Daniel 61 Apache
Daniel 61 Apache's Avatar
Disc conversion crossmember swap
I bought a 85 c10 3/4 ton front clip and was planning on sticking the cross member up under my 61 for disc brakes. Can anyone confirm that the cross members are all the same?
My plan is to buy 1/2 ton calipers, drop spindles, discs, upper arms, lower arms, and cross shafts......then bolt all that onto the cross member and slide it under that 61.
So essentially my question is: When doing a disc conversion on our trucks can an 85 c10 3/4 ton be made to fit under a 61 1/2 ton c10? (FYI I'm baggin my truck also)
Daniel 61 Apache is offline   Reply With Quote
Old 11-23-2008, 12:16 PM   #2
502tripower
502tripower's Avatar
Re: Disc conversion crossmember swap
if it is a 85 C-10 then it is a 1/2 ton and even if it is a C-20 it will work in your 61'. The cross members are the same.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 11-23-2008, 12:50 PM   #3
Daniel 61 Apache
Oops, it is a 85 C20 front clip. 8 lug discs. Either way, you answered my question.
Thanks very much. Daniel
