accepting donations
Kickdown adjustment
What is the proper procedure for adjusting the kickdown cable?
Should there be any slack in it?
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
Between Trucks...
Re: Kickdown adjustment
Adjust so it works at WOT. You can pull on the cable and feel it engage. There may be some slack in the cable at idle.
Edit: This is for a TH350 or TH400...
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 11-23-2008 at 03:22 PM. |
Moderator
![]() Join Date: May 2007
check this site. www.bowtieoverdrives.com
great ifo on TV cable set ups |
its all about the +6 inches
We need to know what kind of tranny you have before the question can be properly answered.
A TH350 or TH200 (400 doesn't use a cable) would be the way Sinister described (there's a more acurate way of getting the adjustment though) If it is a 700 R4 or a 200 4R, then you need to read up on TV cable adjustments, and the BTO link that leddzepp posted is possibly the best way of doing it. |
Between Trucks...
I had a brainfart on the TH400, because I have the Lokar setup which uses a cable operated switch.
Beat it to fit, Paint it to match... ![]() |
accepting donations
Sorry, it's a 350.
I had a 700r4 in my old camaro and I think I used to move the plastice part forward or back. It was 10 years ago so I cant remember.
these pics may be out of order... but you pup the plastic piece up on the assembly with a screwdriver as shown, hold the carb at wide open throttle (engine off) and as you hold the linkage open, you press the piece back down.
Done. |
