11-23-2008, 05:03 PM | #1 |
brake problem
hey guys, need your help! i bought a 1975 c-10 step, one owner, out of a barn. been sitting for 7 years. got it running no problems, did a complete brake job, new wheel cyl. , new calipers, new master cyl. everything new. my problem is i'm getting good line pressure to all the wheels except the L. front. the pedal has to be pushed really hard to get fluid to come out the bleeder. after bleeding it, & tighten the bleeder valve, then pump the pedal, the caliper won't release the rotor to turn freely. it only does this on the L. front. the only thing i can figure is the pressure valve on the very front cross member under the radaitor is bad. any ideas ???? thanks guys, Art
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) |
11-23-2008, 07:15 PM | #2 |
Slots go on anything!
Re: brake problem
Did you replace the brake hoses? Could be a collapsed hose.
11-23-2008, 07:16 PM | #3 |
Re: brake problem
You change the front rubber lines? . If not i,m betting that is your problem
You beat me Jonboy....lol Last edited by ont_guy_38; 11-23-2008 at 07:17 PM. |
11-23-2008, 08:26 PM | #4 |
Re: brake problem
no, i didn't , i will do that this week, thanks guys, hope you're right. Art
11-23-2008, 09:45 PM | #5 |
Re: brake problem
brake hose i'd do them both to save the hassle of having to replace the other one later on
CHEVY ONLY |
