Old 11-23-2008, 07:08 PM   #1
lo72
Truck Junkie
lo72's Avatar
Oil Gauge
Anyone out there know if an after market oil line (plastic) will work or do i need to get a copper one...thanks!
lo72 is offline   Reply With Quote
Old 11-23-2008, 09:02 PM   #2
cparman
sharp as a marble
Re: Oil Gauge
I would use copper. I have a low opinion of the plastic tubing. GM used nothing but copper for years.
cparman is offline   Reply With Quote
Old 11-23-2008, 10:24 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Re: Oil Gauge
I used plastic for awhile because I had it lying around. I switched it to copper though and wouldn't do plastic again. I think I paid less than $10 for the copper line and it's really easy to bend. I was always worried about the plastic rubbing something and getting a hole in it. Go copper; just my .02
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 11-24-2008, 02:05 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Re: Oil Gauge
Yep, go copper. But if you must have the plastic line, I'll give you the one from my Camaro as it's getting copper in the near future.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-24-2008, 07:11 AM   #5
70GMCer
70GMCer's Avatar
Re: Oil Gauge
I had plastic let go a long time ago. Not fun, & what a mess. Ever since then, I use copper.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-24-2008, 08:33 AM   #6
cdowns
cdowns's Avatar
Re: Oil Gauge
with copper so readily available why think plastic? go to NAPA get the good stuff
Old 11-24-2008, 03:28 PM   #7
lo72
Truck Junkie
lo72's Avatar
Re: Oil Gauge
Thanks Guys! Yep i'm guessing go with copper is the answer....
Old 11-24-2008, 07:19 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Oil Gauge
I agree with all of the above... The only time I've had an oil leak in my vehicle was whith a nylon oil tube. Oh, and when I buggered up the threads on a copper line.
68gmsee is offline   Reply With Quote
Old 11-24-2008, 08:03 PM   #9
smoked68
smoked68's Avatar
Re: Oil Gauge
I had the plastic line bust years ago in my 66 Mustang.50 psi and carpet don't mix very well. Go copper, it wont let you down.
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
