weird generator light
my generator light is coming on at idle, when the rpms increase to like 1000 or 1500 the light goes out. the light will also come on when i turn the headlights on or turn the heat on high. i did the internal regulated alternator conversion about a year ago with no problems. the alt is from 1982 caprice, battery is old, 12.5 volts engine off, 15.4 at 3000 rpm (isnt this to high?) what could be causing this, every thing else seems fine. thanks in advance
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
Re: weird generator light
Change internal regulator.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
its all about the +6 inches
If you were to check it at idle, it is probably low.
Either way, that 15 is too much... replace the regulator if you are handy/capable... the whole alt if you aren't. |
