I like turtles...
first time welder, what u think?
hey guys, my dad recently bought a welder, so he taught me how to weld some. so here are some pics, now i kno they arnt the best welding ever seen, but this is the 3rd time ive welded. and i havnt grinded it or nothin, so here are some pics
![]() them just layin in ![]() the front ![]() ready to weld ![]() new welder ![]() front welded (dont laugh) ![]() doors (same) ![]() how does it look?
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock ![]() Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. |
Re: first time welder, what u think?
dude you need to turn your wire speed and heat way down that is why it is popping like that
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada ![]() MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm MMA RECORD 24-5 |
I like turtles...
the welder is an automatic wire feeder by the trigger, so i cant set it, and the setting was on 3
Built 4 Speed
for it being flux core wire you are using it does not look bad for a first timer at all.. it may be your speed and heat but it looks like the gun needs to be alot closer to its target. like 1/4"
if you plan on doing alot more welding i would highly suggest buying a argon tank and using a .030 size wire. will make the job 1000 times easier for you to learn how to make good quaility welds. find some scrap sheet metal. and fine tune your welder. with flux core you need to take the wires brush and clean the metal everytime you make a pass.. being that your shaving stuff. be very careful not to get that metal to hot in surrounding areas. Looks good tho Keep us posted.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" Last edited by d10s69c10; 11-23-2008 at 09:34 PM. |
I like turtles...
thanks man, yea i have an old tailgate ive been practicin on, i still need to smooth out the welds, it dark waay to soon now-a-days
Happy to be here
![]() Join Date: Mar 2000
Something else I would suggest is a good quality extension cord. If the orange one laying on the ground is your power source, then it's too small. Eventually it will cause problems especially if you don't have a good ground.
fyi if you dont cover your glass up while welding you will be replacing it from the weld splatter
Built 4 Speed
ooh good point on the wire.. N2
and yes it does seem that the bright warmth of the sun is dropping faster than the stock markets these days.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
I like turtles...
what is that blue nob on the welder ?
I like turtles...
the power level of the weld
not too bad for a rookie. I have seen those welders before i used to have one that was a little bit better. put it on the low power setting and drop that feed speed to 1-2. On that sheet metal it will burn through very quick. so, prepare that metal very very very well!!! it needs to be as clean as possible. another suggestion, the paint that you ground away right next to your weld, is too close. The heat from the weld will suck that paint/dirt right into the weld making it harder to lay down a solid tack/bead, it will also create more splatter. Being a good welder is all in the metal preparation and knowing/understanding how to set up the machine correctly. Once you learn that, you will be amazed at how good you get. keep workin on it!
#13 |
I like turtles...
yea i agree, i was gettin anxious to try to beat the darkness, tomorrow when i do the other side, i will sand alot bigger area
thanks for all the comments guys!
#14 |
I like turtles...
my dad also bought one of them auto-darkenin masks, they are amazing
#15 |
I like turtles...
heres what i got done today
#16 |
Dually Pride
cool! im just learning to weld too, but just got we've got a crappy 80 amp schumacker welder, but its ok for now. my dad cant mig weld only arc so i learned a bit in school but its mostly self taught. best of luck to you!
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
#17 |
is that fiberglass? hope not
#18 |
Moderator
![]() Join Date: Jun 2008
I didn't know this when I first started welding, but you should be able to adjust the wire speed where the spool starts feeding through the welder. On many of the inexpesive welders, there is a little dial that adjusts the wire tension, and controls the speed. It looked like you had an ok start. I would have grinded that area that you welded flush before putting any filler. You may want to consider doing so. The residue left from the burning of the welder will make for bad adhesion. Other than that and what advice others have given you, you are on the right track.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 11-24-2008 at 10:38 PM. |
#19 |
I like turtles...
yea thats fiberglass, its fiberglass resign, made by bondo. yea i made the area flush with a grinder before i but that fiberglass resign on
#20 |
#21 |
I like turtles...
yea the heat leavel is, but there is no wire feed adjuster knob
#22 |
I like turtles...
here is what i got done today
![]() ![]() ![]() ![]() ![]() had to modify the door panels ![]() ![]()
#23 |
Built 4 Speed
your really getting on it.. Power to ya man.
#24 |
67lwb
![]() Join Date: Sep 2007
Not to burst any bubbles. It is absolutely important that when welding that you have both sides of metal properly cleaned ESPECIALLY WITH MID AND FLUX core wires. What happens when welding on a painted or dirty surface is that your heat burns the paint or foreign matter off of the metal this increases the heat and actually burns off your shielding gas when welding. All in all for a rookie welder and for a vertical weld it looks decent. Prep work in welding is one of the most important steps for both penetration and looks.
Keep trying and like I said clean off both sides of the panel at least two inches away from the area to be welded of all paint then take an alcohol based cleaner (rubbing alcohol) to ensure that you have no grease or oil on the surface to be welded and you will cut down on the amount of splatter from the weld. some other useful info. 1. splatter shields are not needed (nozzle dip etc) 2. weld small tacks do not try to weld a bead on sheet metal 3. clean clean clean especially before welding and again after your tacks just wire brush in between welding and it will help again |
#25 |
I like turtles...
yea i agree, ill get some Gilette to clean the other side before i weld it up
