Old 11-23-2008, 09:12 PM   #1
tim21391
tim21391's Avatar
Welding vs. Glueing
went to local part store to look for this special type of bondo i use at the body shop i work with... not sure the name we call it marr glass... but its dark green and it has kevlar in it... and the ppl at autozone said to glue my cab corners in because the project starts in about 2-3 weeks... anybody ever tryed that???
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-23-2008, 09:27 PM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: Welding vs. Glueing
I use glue almost every week......Its a great product.....But for something as a cab corner i would just butt weld it....You can glue it , but it would require a over lap type of fitment....
bad6772 is offline   Reply With Quote
Old 11-23-2008, 09:33 PM   #3
bigsnookmaster
bigsnookmaster's Avatar
I would weld it.I would think metal and glue expand and contract differently.My .02
bigsnookmaster is offline   Reply With Quote
Old 11-23-2008, 10:04 PM   #4
Painter D
Painter D's Avatar
Those glues work well for some things ,but on a cab corner I would weld it.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-23-2008, 10:35 PM   #5
Peter82
Everything is Custom
Peter82's Avatar
the glues are good because they have a good corrosion protection to them but you have to wipe off the excess glue. also if you leave glue exposed and cover it with plastic body filler (bondo type). when heat is applied to it, it will more then likely expand and you will see the lines in the paint. just but weld it and fill in the pits with body filler.
Peter82 is offline   Reply With Quote
Old 11-23-2008, 10:58 PM   #6
PHAT TONY
PHAT TONY's Avatar
My experience is certain "metal adheseves" will soften or lose adhesion with heat. I've removed "bonded" pieces with a heat gun (no gloves!)
PHAT TONY is offline   Reply With Quote
Old 11-23-2008, 11:07 PM   #7
bad6772
bad6772's Avatar
I doubt it was a Panel Adheasive...Or Panel Bonder Such as 3m or Kent.....As i said above....Glue has its place....And this in not one of them....And to add what others have said....There is a (ghosting effect) that can and will (over time) come to the surface...Just but weld it......Its the easiest and BEST way........and the RIGHT way
Old 11-23-2008, 11:54 PM   #8
chevy29267truck
i like welding better my self i cut out and welding in new stuffel on my 67 chevy truck door inner bottoms some flooring cab corners
but there are some things you can used glueing or puttely on and note this i will never used bondo on any of my chevy trucks or calls
chevy29267truck is offline   Reply With Quote
Old 11-24-2008, 12:14 AM   #9
PHAT TONY
PHAT TONY's Avatar
You can doubt what ever you like, the peticular product in this case was Duramix Structural Metal Bond-OEM approved , and I DID remove said repair with less heat than expected.
Old 11-24-2008, 12:17 AM   #10
tim21391
tim21391's Avatar
cab corners are ordered and on their way.. my buddy of mine is going to let me borrow his 110 mig welder.. and im going to get some bondo soon its heavy duty stuff that has kevlar in it.... so it will be good.... other friend has a cut off wheel so it should be done in a weekend so after thanksgiving ill update you guys...
Old 11-24-2008, 12:23 AM   #11
bad6772
bad6772's Avatar
I would have to see the way it was applied and to what it was applied to comment....I am not saying its not possible....But when done correctly its unlikely .........But what do i know i only do this everyday.
Old 11-24-2008, 12:25 AM   #12
Gregs67
I personally do not like leaving an overlapped pocket to catch dust/debris/moisture on any kind of glued panel,.....but I have never used it, so I cannot judge it.
Gregs67 is offline   Reply With Quote
Old 11-24-2008, 12:37 AM   #13
bad6772
bad6772's Avatar
I agree Greg especially in this case.....
Old 11-24-2008, 08:46 PM   #14
Painter D
Painter D's Avatar
Agreed
Old 11-24-2008, 09:17 PM   #15
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
what i do is when u tack weld or bead, put some of the green "glue" everywhere the weld isnt, sand the bondo over that and make it smooth
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
Old 11-25-2008, 12:57 AM   #16
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
Hey JR, not picking on you but just making sure that any "newbies" on here reading this understand what you mean by "bead".
Never, never, never bead-weld sheetmetal. (1" inch long welds are WAY too much, even welds 1/4" inch long are pushing it) You are just asking for trouble. Put a small stich weld then cool (think of a single stick in sewing), stitch and cool, stitch and cool. Even going slow you will warp it some, but is fixable.
Go slow and you will be fine but run a "bead" and you will warp the crap out of your cab that may not be fixable even with a ton of filler being added! I added a pic to show what I mean by stich welding. This is my cab when I had to fix the fuel hole area.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 11-25-2008, 01:19 AM   #17
chevy29267truck
Richard8971 thats a very nice job
Old 11-25-2008, 01:24 AM   #18
hdflstf
hdflstf's Avatar
Weld it. You want to maintain the structural integrity of the cab.
hdflstf is offline   Reply With Quote
Old 11-25-2008, 01:29 AM   #19
Shane
Shane's Avatar
Jeez ... all this glue talk is gonna put the pop rivet companies out of business.
Shane is offline   Reply With Quote
Old 11-25-2008, 02:28 AM   #20
Richard8971
Naw, they will be around forever... too many tweakers and bubba's out there! (I was going to say rednecks, but I didn't want to offend Jessie! )
Don
Sherlock Holmes
Old 11-25-2008, 08:57 AM   #21
Hair
Weld her up solid!
Hair is offline   Reply With Quote
Old 11-25-2008, 09:19 AM   #22
jrsmith_2010
I like turtles...
rookie moment
Old 11-25-2008, 09:32 AM   #23
Hair
Inside View. Skip around and weld small stitch/tack welds until it is welded solid and then sand it smooth. Keep the big grinding rock off of it. In some places you will sand through. Stic a bright light behind the weld and you'll see all of the little pin holes. Then I get on the back side and go down through there and touch up each little hole until it is all solid. It has worked better for me to touch it up from the back side when you can. Here's the back side. I will go back and sand it "fairly" smooth too. If you have a gap in the seem when your panel is fitted, then you stick a piece of copper behind the gap and weld it up. The copper trick will save you a lot of grief.
Old 11-25-2008, 09:35 AM   #24
Hair
oops
