Oil Pressure Gauge
They factory oil pres. gauge in my '68 comes on and stays on the whole time the truck is running. But I have an aftermarket gauge installed, and it seems to work normally. What would cause this to stay on?
Re: Oil Pressure Gauge
Dave's not here, man
Do you mean the idiot light comes on and stays on, but your mechanical gauge show good pressure? If you disconnected the old sending unit and didn't move it out of the way, it could be grounding out on something causing the light to come on. This has happened to me before.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Ya something like that. I will go check and see where the old sending unit is
#5 | |
Active Member
![]() Join Date: Jul 2007
I haven't had a light for the oil pressure in a long time, but I believe that if you disconnect the sending unit, the lite is supposed to come on. It was my understanding that once the oil pressure built up, the sending unit would shut it off... I think. Maybe someone can correct me if I'm wrong... |
It's just the idiot light in the gauge cluster. It lights up red and stays on
Mine has been diconnected for years, never comes on. I always had a mechanical oil press. gauge, so I took it off a looong time ago.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
