Old 11-24-2008, 11:18 AM   #1
55Series2
VIN Plate Location
I have the remains of a '64 C10 that I'm parting out. Where is the VIN plate located?
John
Albuquerque, NM
'55 2nd Series 3100
'57 Ford RanchWagon
07 H-D Electraglide UltraClassic
55Series2 is offline   Reply With Quote
Old 11-24-2008, 11:31 AM   #2
mnky30
mnky30's Avatar
Re: VIN Plate Location
should be located drivers door jam on top by the roof.
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 11-24-2008, 11:34 AM   #3
LILRED66
LILRED66's Avatar
The VIN is located on the underside of the driver side door jamp...where you bump your head when you get in, if you don't duck.
LILRED66 is offline   Reply With Quote
Old 11-24-2008, 12:49 PM   #4
oldfart
oldfart's Avatar
Seems that everyone will tell you where they "think it should be.I got on here with the same question & still haven't found mine.
Once again I will say,The data plate on the top of the door frame is NOTthe vin plate..Keep lookin.If you find one,please let me know where it is.
oldfart is offline   Reply With Quote
Old 11-24-2008, 12:56 PM   #5
LILRED66
LILRED66's Avatar
oldfart:
If you have a 4-5-6 Chevy truck, series 10-30 C/K, the VIN plate, as installed at the manufacturer, is located on the driver side door jamb, so if yours isn't there, someone has removed/relocated it.
That is the correct location and that is the VIN tag, so you might want to check your information source and good luck finding yours. If yours isn't there, it should be, because that is where they were installed.
Old 11-24-2008, 03:14 PM   #6
502tripower
502tripower's Avatar
Originally Posted by LILRED66 View Post
oldfart:
This is also true for 60-63...and Oldfart if yours is not there then as Tony said it has been removed.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 11-24-2008, 03:27 PM   #7
joe231
joe231's Avatar
with LILRED66 and 502tripower.
I'll post a pic tonight of mine on our '66
CHEVY ONLY
Old 11-24-2008, 04:17 PM   #8
jchav62
1962 C-10
jchav62's Avatar
On a 60-63 the vin plate is on the front vertical pillar in the door jamb.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
