Rear control Arm SWB / LWB question
I have a 69 LWB and just bought a 69/70 SWB for the cab. the guy threw the short bed and frame in for free... it was to good to pass up. and by looks it seems as if the Rear Control arms on the SWB look better then the ones on my LWB do. are they the same length. In LMC they only offer one length control arm. so i guess my question is, bo both the LWB and the SWB use the same control arm?
Thnaks guys for all your help |
Re: Rear control Arm SWB / LWB question
For that matter, I have always Heard that you can put a SWB bed on a LWB truck all you had to do is just cut the frame is that as in cut the end of the frame off? or cut some frame out in the middle?
![]() Join Date: Jun 2002
Trailing arms are the same.
You cut from the middle and weld together to make a lwb a swb, but if you have the swb frame I would use it. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Next project: 1970 K10
Yup, arms are the same.
To cut a LWB frame to a SWB frame means taking 12" out of the middle, 8" off the back.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 11-24-2008 at 04:17 PM. |
problem is i just needed the cab. everything on the LWB is pretty much new.
just always like the SWB. |
