11-24-2008, 04:56 PM | #1 |
2 piston brake calipers
Are there any 2 piston calipers from other GM vehicles we can use on our trucks when doing a brake disc swap?
11-24-2008, 06:56 PM | #2 |
Re: 2 piston brake calipers
deleted
11-24-2008, 07:29 PM | #3 | |
11-24-2008, 08:42 PM | #4 |
Anybody??? Gotta be somebody who has looked into this.
11-24-2008, 08:43 PM | #5 |
I'd like to know as well.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
11-24-2008, 09:20 PM | #6 |
camaro calipers, chevelle rotors if you want 5x4.75 bolt pattern. it all works, camaro calipers i had on mine but soon im going to get the 13'' big brake from mcgaughys....
11-24-2008, 09:21 PM | #7 |
oops....sorry i believe camaro calipers are not dual piston....sorry....the parts i was talkin bout is from 68 camaro calipers. 71 chevelle rotors. sorry i believe its a single piston though
11-24-2008, 09:22 PM | #8 |
Grease Monkey
Early Classics Enterprises in Fresno,CA has an awesome setup. 559-291-1611
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
11-25-2008, 01:23 AM | #9 |
i checked their site and only saw 1 piston calipers. Maybe i missed something. I am trying to build a kit using 73-87 parts but with dual piston calipers from another vehicle. I thought for sure there was something out there. I guess we will see as more responses to this thread come in.
11-25-2008, 01:39 AM | #10 |
Never Ending Projects
Actually the only "bolt on" dual pistion calipers I have seen for the GM D52 mount (i.e. the stock single piston ones until the "metric" style came into play) are made by Howe Racing and Stainless Steel Brake Company. Someone on the board tried them out and the only issue they found was where the pins ride in the caliper, they are not machined to use the "o-rings" so they have a little play in them. I haven't seen anyone using the SSBC ones but haven't searched that hard.
Most "big brake" kits require modifying the spindle by cutting the caliper ears off, drilling and tapping a couple holes and using a bolt on bracket that allows GM style PBR dual pistion calipers. This is mainly what Baer brakes does on a number of GM applications. Good luck on your search and share what info you find.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-25-2008, 04:17 AM | #11 |
Out of the carpool lane.
Ackattack did this and had a thread recently.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-25-2008, 08:54 AM | #12 | |
11-25-2008, 01:46 PM | #13 |
11-25-2008, 03:30 PM | #14 |
There is some info about them in my build thread, and then this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=307288 Basically, I think I'm going to get some delrin bushings made that will press fit into the calipers. I haven't gotten around to figuring out the specs for the machine shop to make them for me. |
11-25-2008, 11:15 PM | #15 | |
11-26-2008, 12:15 AM | #16 | |
I really think a lot of improvements can be made by simply upgrading to a good brake pad. In addition to the Howe calipers, I'm also using some Hawk HPS pads, and that's probably where a majority of braking improvement will come from. |
11-26-2008, 12:36 AM | #17 | |
11-26-2008, 12:44 AM | #18 |
There was some info about Kore3 offering a big brake kit that uses a corvette caliper. It also used a corvette rotor, a bracket, and a special hub to allow you to use the corvette rotor. Last time I checked it wasn't available yet.
11-26-2008, 01:07 AM | #19 | |
i havent ordered the kit yet. but when i do come to that point, thats the route im going. |
11-26-2008, 09:17 AM | #20 | |
11-27-2008, 01:25 AM | #21 |
ya im sure baer is really great, and works awesome but a couple grand for brakes... even if you just paid like 12 hundred for front and another 12 for back...thats 2400 for 4 wheel disc baer brakes....ALOT OF MONEY. MAYBE ITS WORTH IT BUT I WILL NEVER KNOW I JUST CANT AFFORD TO SPEND A COUPLE GRAND ON BRAKES. MCGAUGHY'S DOES SEEM TO BE GOOD THOUGH....ABOUT 700. I BELIEVE STUNNA SAID YOU CAN GET THEM FOR ABOUT 500 FROM GODFATHER CUSTOMS....HAVENT CALLED YET..
11-27-2008, 07:48 PM | #22 | |
11-28-2008, 11:36 PM | #23 |
Anybody install mcgaughys big brake kit??
11-28-2008, 11:36 PM | #24 |
bump, bump
12-08-2008, 09:30 PM | #25 |
just an update on this. I found out today that performance online has a 2 piston aluminum caliper for 71-87 trucks. You have to trim about 1/4 off your spindle, but no special brackets! The price is $184.00 a pair and 95.00 more for polished. They are not the Howe calipers that they were selling ( i asked) They don't have it on their website yet but they are available NOW There is a picture of the single piston version in the Dec issue of CCT. Finally something affordable!
