Old 11-24-2008, 07:21 PM   #1
ironmanl21
eaton disk brakes
has anyone done a disk brake conversion on a eaton rear end?
i have a 68 k20 without power brakes (for now)
ironmanl21 is offline   Reply With Quote
Old 11-24-2008, 09:16 PM   #2
MJN
MJN's Avatar
Re: eaton disk brakes
I started putting disc's on mine before I sold the truck it was in. I put Dana 44 rotors on it from a Chevy K-20 axle, 14 bolt disc brake brackets will work. The backing plate flange has the same bolt pattern as a 14bolt except the eaton's are fine thread bolts. Then you can run Dana 44 calipers and pads. Pretty simple. These are the brackets I used.
http://cgi.ebay.com/ebaymotors/14-Bo...3994QQtcZphoto
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 11-24-2008, 10:12 PM   #3
ironmanl21
so just the same as on a fourteen bolt thats easy enough thanks alot!
Old 11-25-2008, 10:07 AM   #4
Elephanthead
Wait, I am confused, I bolt these brackets where the backing plate was, and I can buy Dana 44 rotors that will fit on the Eaton axle shafts? How about dually rotors? I have a C30 but the axle is the same only shorter. It needs new brakes so rather then fixing what is on there, it is about the same to do a conversion. I was about to order new parts for the drums but this look interesting.
Elephanthead is offline   Reply With Quote
Old 11-25-2008, 11:21 AM   #5
Sinister
Between Trucks...
Sinister's Avatar
Subscribed.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-07-2008, 05:18 PM   #6
MJN
MJN's Avatar
I don't know about the dually part. The brackets would probably be different than a SRW axle and I don't know if Dana 60 dually rotors would fit. The rotor gets held to the hub of the axle with the wheel studs and the axle shaft gets bolted back on. For dually stuff, I would check a junkyard and see if there is some way to swap on a setup off a new dually axle.
'17 GMC Yukon XL
VCCA member #58596
