Old 11-28-2002, 01:18 PM   #1
Low69CST
Motor pics, for real this time
pics
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 11-28-2002, 01:19 PM   #2
Low69CST
a
Old 11-28-2002, 01:20 PM   #3
Low69CST
b
Old 11-28-2002, 01:21 PM   #4
Low69CST
c
Old 11-28-2002, 01:22 PM   #5
Low69CST
d
Old 11-28-2002, 01:23 PM   #6
crazy longhorn
Fabricate till you "puke"
Low69CST, what dual fan setup are you running?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-28-2002, 01:26 PM   #7
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Thats SWEET! How about the specs on it? And what kind of headers are you running? They look real nice too. Can you tell us what kind they are? Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 11-28-2002, 01:35 PM   #8
low 84
low 84's Avatar
Thumbs up
serpentine setup looks great on there
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 11-28-2002, 01:42 PM   #9
Low69CST
I'm running a flexalite set up. I don't like the fact that the shroud set up is about 2-3 inches narrower and about 2 inches shorter than the radiator tube area. But the fan works perfect. I broke in my cam, running about 2,000rpm for almost 30 minutes. Truck hit 205 once and stayed 200 about 98% of the time. Those headers are Headman truck headers. They are decent, had to reroute some break lines for safety and they come real close to the frame but don't touch. The motor is a '72 400ci. I put a speed-o-motive 415 stroker kit. 3.832" stroke (I think), bored .030 over. I have a comp cams 284 Xtreme energy flat-hydraulic, Victor jr. intake, Dart Iron Eagle heads, rebuilt Holley 650 double pumper. Thats the basics, done a few other tricks to it. The serpentine system is off a 84 vette, took the air pump off and got a shorter belt. Truck really sounds mean. Dad says it sounds like the late 60's Z-28's except alot deeper.
Old 11-28-2002, 02:05 PM   #10
crazy longhorn
Wow, that sounds like a really nice combo! Bet you cant wait to "play" now
Old 11-28-2002, 02:40 PM   #11
Mudder
Mudder's Avatar
Love those valve covers!
Mudder is offline   Reply With Quote
Old 11-28-2002, 03:13 PM   #12
racedvl
racedvl's Avatar
I really like the p/s revesior up high from the pump to easy fill. That is really slick!
racedvl is offline   Reply With Quote
Old 11-28-2002, 03:30 PM   #13
lukecp
Formerly yellow72custom
lukecp's Avatar
Wow....your truck is gonna haul . I would be tempted to leave the outside flat black, and have a sleeper.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-28-2002, 11:46 PM   #14
72ChevyCheyenne
72ChevyCheyenne's Avatar
Here is mine.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 11-29-2002, 12:15 AM   #15
67cst
i love summertime
67cst's Avatar
damn guys those are sweet, i thinkyou should stay flat black too man
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
