Old 11-24-2008, 11:45 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
I need new tie rods
I am converting from drum to disks and I need to replace the Tie Rods.
Should I replace the whole thing or just the end? What brand are you using? Where are you buying your parts?
We have an Auto Zone, Advanced Auto, Napa and a few other local auto parts houses. Thanks
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 11-25-2008, 09:42 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: I need new tie rods
if they are original i personally would replace them all. We bought ours from Autozone, but NAPA would be a good choice. Get the ones made in America. Good luck with your conversion.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-25-2008, 11:52 AM   #3
71tahoe
71tahoe's Avatar
Are you using stock spindles, aftermarket, drop?
Some aftermarket spindles will let you use the original yr tie rod end. Stock and most aftermarket will require '71 and up outers. You will most likely need a special tie rod adjuster or the whole linkage from a '71 and up truck.
71tahoe is offline   Reply With Quote
Old 11-25-2008, 01:41 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Replace the whole thing. They will be much easier to adjust when you get the front end re-aligned. If you have the money, use Moog suspension parts.
leddzepp is offline   Reply With Quote
Old 11-25-2008, 07:37 PM   #5
myoldchevytruck
Can actually order Moog thru Advanced Auto. Ledzepp, hoping the cash will let me get the Moog Parts but if not - I'm gonna buy the TRW Parts. They are also made in the USA and carry the same limited lifetime warranty as Moog.
BTW, there stock Spindles. Thanks guys for all the input.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
