Old 11-25-2008, 04:38 AM   #1
LeDevil
A new C10 Addict!
LeDevil's Avatar
Crooked frame
This doesn't pertain to my truck but to a friends. I was following my friend over to his house when I noticed his truck was driving sideways "crooked" When we got to his house I looked down both sides of the truck and sure enough the driver side front wheel was about a inch and a half farther out then the rear. I looked at the other side and the complete opposite the front wheel was pushed in about a inch and a half. Crawled under the truck and there was two nice sized buckles in the frame right under the cab. So my question is what would it take to straighten his frame other then a new frame? Asked my friend and he said he didn't know what happened as far as he knew it was that way when he got it.
LeDevil is offline   Reply With Quote
Old 11-25-2008, 05:02 AM   #2
shrtbx
Re: Crooked frame
my guess is you would have to take it to a body shope and, if its possible, get the truck on a rack and have it pulled to straightness. Theres alot more involved in that though but i would think that would be the only way it could be corrected.
shrtbx is offline   Reply With Quote
Old 11-25-2008, 06:23 AM   #3
Ds86C10
2WD 4 Life
Ds86C10's Avatar
Re: Crooked frame
its not a bent frame. the frame has bends in it for the cat to clear from what i've read. to me it sounds like you need to look at the suspension, have a alignment shop look at it.
Big D
1969 c10
1960 cadillac
1978 king cobra
Ds86C10 is offline   Reply With Quote
Old 11-25-2008, 11:12 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Crooked frame
my friend had a 78 Blazer and what had happened to him was the frame cracked by the steering box thus causing the thing to drive crooked... I dont know if its the problem with your truck or not... the body shop and allignment shop are where you need to go first if you cant visibly see a crack or a bend.. also pics will determine if those bends are normal or not
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-25-2008, 11:36 AM   #5
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: Crooked frame
Take some measurements on the frame if you can - corner to corner. I know it will be tough with a truck mounted to it but if the frame is square, the measurements should be equal.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-25-2008, 12:15 PM   #6
skidder111
skidder111's Avatar
Re: Crooked frame
If the truck is a 4x4, the front axle is wider than the rear. It's the way GM did it. Why? I don't know. It is usually 2-3" wider. I would check the center bolts on the rear spring packs first. They do break and would cause the truck to "dog-track".
skidder111 is offline   Reply With Quote
Old 11-25-2008, 02:26 PM   #7
84 400
Sb 400 club
84 400's Avatar
Re: Crooked frame
on my 4x4 willys the rear axle sticks out on the passangers rear and is in on the drivers side. My leaf springs are heavily sagged and the one is wrapped a bit. I am going to replace them and it should correct my problem or so I hope. IS it a 4x4? they had some known week spots and I have seen many broken in half.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-25-2008, 04:08 PM   #8
kevinr1970
Re: Crooked frame
More info; is it a 4x4 and is it lifted?
If yes and is lifted with blocks in the rear then I would start there.
On my old Suburban with 4" blocks it would start to "axlewrap" (what the guy at the 4x4 store called it?) and it would start dogwalking.
He said it gets worse with 6" blocks.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 11-25-2008, 05:13 PM   #9
84 400
Sb 400 club
84 400's Avatar
Re: Crooked frame
6 inch blocks.. Dang. And here I was thinking 4 inch blocks where huge. My buddies and I go wheeling quite a bit and the biggest blocks any of us run is 2 inch. All other lift is spring and shackel flips. Sorry to be off topic
1985 C10 LWB Sold
Old 11-25-2008, 06:18 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Crooked frame
It makes them turn/track easier?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-25-2008, 07:25 PM   #11
kevinr1970
Re: Crooked frame
I was told that it was so your rear wheels didn't fall into the same track as the front in snow, sand, mud, etc.
You still have some bite with the rear tires?
2000 Tahoe Limited
Old 11-25-2008, 07:47 PM   #12
74 shortbed 406
Re: Crooked frame
^^^ thats what I was told, and look at pulling trucks(4x4 ones) rear is always narrower than front. And also, a narrower rear gets better traction than a wide rear. And also if it is 2wd, I know where there is a good frame(85)
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
