Old 05-11-2002, 07:02 PM   #1
Spoof
Spoof's Avatar
Question Flexplate removal help
None of my three chevy truck books covers flexplate or flywheel removal, so I assumed it would be simple. Dammned if I can remove the one on my 307. After removing all the bolts it will move sideways but not off the crank shaft. Is there a trick to it? I retreated rather than risk damaging it but I needs to come off tomorrow. The original service manual instructions are "remove flywheel" lol
Maybe there's a puller?
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 05-11-2002, 07:15 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Post
It's a tight fit but should come off without undue force. No puller needed that I'm aware of.
Jeff Jesseman
Cheyenne Parts Northeast
Franconia, NH
67 Chevy SWB Fleetside
70 GMC Burb 1/2 ton 2wd
72 Chevy Burb 3/4 ton 4x4
Parts bought and sold
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-11-2002, 07:55 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
pull harder, just dont get hurt. sometimes flywheels are on pretty tight or hard ot reinstall, but flexplates always are easy
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, a driver
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-11-2002, 09:51 PM   #4
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
flexplates are a pretty snug fit, you just have to wiggle and pull at the same time and they usually come off pretty easy, sometimes, if there is a rust ring around the flexplate on the crankshaft, you have to uses some emery cloth and sand the rust off. I have had them stuck tight enough i couldn't wiggle them at all, just whap it with a dead blow hammer or a bfh and a wood block, it will come off sooner or later, don't use a prybar or something on it or you will take a chance of bending it.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
my site:
http://communities.msn.com/Beastonabudget/homepage
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-12-2002, 01:14 AM   #5
bigjimzlll
bigjimzlll's Avatar
Post
try some liquid wrench or wd40 to free up the rust
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 05-12-2002, 08:16 AM   #6
tom hand
CCRider
tom hand's Avatar
Post
I think Ol'buck has the correct answer for your problem. I think you will find rust is the problem and sandpaper is the answer. Just keep sanding the center part that sticks thru the flexplate till it is nice and shiney, then it should pull right off.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-12-2002, 08:46 AM   #7
Mike C
Mike C's Avatar
Post
I agree with the other guys. I'd try a wire brush on an electric drill to clean the end of the crank where the flexplate pilots, followed by some WD40. Then wedge a piece of wood on one side under the flexplate and pry from the opposite side levering the flexplate against the wood and it should pop right off.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 05-12-2002, 10:52 AM   #8
69 longhorn
Post
Just remember that as already posted,it is very easy to damage a flex plate.......I think I would clean the rust ring,& shoot a little "goose juice" on the crank,then try to wiggle it off..........69longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-12-2002, 02:33 PM   #9
Spoof
Spoof's Avatar
Post
Thanks for all the good tips. Wire-brushed, sanded and lubed and it eventually worked off by hand. A great spring day to be out working on it too.
71 GMC 2500 Custom Camper
71 GMC Suburban 1500 Super Custom
71 Chevrolet 1500 Donor
http://www.able-bravo.com
71 GMC 1500 LWB
