Old 11-25-2008, 05:49 PM   #1
pete29
how much play should there be in a steering box
i recently bought a brand new remanufactured steering box and got it on and when it is running or when it is just setting there you can move it about a 1/4 turn. Just wondering if this is normal and how firm a remanufactured box should be. Also is there is any way to get the play out.
pete29 is offline   Reply With Quote
Old 11-25-2008, 06:01 PM   #2
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: how much play should there be in a steering box
The play might be elsewhere too. The rag joints on the shaft might be worn out. Every box i've put on have been pretty solid.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-25-2008, 08:21 PM   #3
pete29
No the out put shaft doesn't move
Old 11-25-2008, 08:32 PM   #4
ERASER5
ERASER5's Avatar
The rag joint still could be part of the problem. Have someone turn the wheel while you watch the joint. If that is OK, the the you can adjust the gears. Now, I would not be too happy about it as you just bought it, but push come to shove, I would adjust it. And I would contact the manufacturer.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-25-2008, 11:09 PM   #5
pete29
how do you adjust it.
Old 11-26-2008, 12:53 AM   #6
72lb4x4
These aren't like the racks on the newer cars/trucks, but it seems like a lot of slop.
I'd say you need to start at the beginning, which is the rag joint and move to the last point, to see where things are going wrong.
Try having someone move the wheel back and forth while you observer the movement in the parts involved.
I think 4-wheeling tends to make the rag joint more flexible than desired...
72lb4x4 is offline   Reply With Quote
Old 11-26-2008, 04:13 AM   #7
ERASER5
ERASER5's Avatar
Look on the top of the steering unit. There is a jam nut on a allen head stud. Put a wrench on the nut and an allen wrench in the hole. Hold the allen wrench in place as you loosen the nut. Now tighten the allen wrench a little, tighten the jam nut, check for play. Too loose = much play. Too tight = binding and wheels will not "return-to-center". Like the three bears, you want the setting that is "just right!" I carried my 2 wrenches with me for about a week. I would stop about a mile down the road and do an adjustment. I probably made about 5 adjustments before I was happy. These were very small adjustments to get the right "feel."
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
