Old 11-25-2008, 08:38 PM   #1
junkman1jmc
junkman1jmc's Avatar
48 gmc on a 87 s10 frame
my s10 is bagged and lays the frame flat on the ground.i found the diagrams for the cab mounts that spaces the cab 5 and 5 3/4 inches. my ? is can i layout on the running boards with these cabmounts or do i need to make them shorter or taller ?? thanks for the help
junkman1jmc is offline   Reply With Quote
Old 12-01-2008, 11:57 AM   #2
stodd16
Re: 48 gmc on a 87 s10 frame
from what i have seen it will set the running boards about 2 inches off the ground.
stodd16 is offline   Reply With Quote
Old 12-01-2008, 07:14 PM   #3
junkman1jmc
so you think i should lower my cab mounts by 2 inches and it should layout on the runnin boards
Old 12-01-2008, 10:37 PM   #4
mr48chev
mr48chev's Avatar
The running board is usually even with the bottom edges of the fenders. I have seen a couple of trucks that guys raised the running boards up closer to the bottom of the cab and trimmed the bottom of the fenders off a like amount to be able to get the truck a bit lower in profile. I think if you were to measure a stock truck you could see where you could take up a couple of inches there.
I'm not into bagging trucks or laying frame (just not my thing) but I do run my truck plenty low.
This truck was at the Run to Roslyn (Roslyn WA) last year and if you look close you can see that the gap between the bottom of the door isn't as wide as the normal space.
This 54 has the running boards raised or appears to
This one has the boards in stock position
Old 12-01-2008, 10:51 PM   #5
junkman1jmc
i plan on sittin the cab off the frame high enough to leave the runnin boards stock and even with the bottom of the frame
Old 12-07-2008, 12:35 PM   #6
junkman1jmc
here is a pic of my truck
Old 12-07-2008, 12:37 PM   #7
junkman1jmc
i'm still learning how to post pic any tipson posting?
Old 12-07-2008, 08:58 PM   #8
OrrieG
OrrieG's Avatar
Put the photos on your computer in jpg format. Reply to a post and click advanced. Click "manage attachments". A window opens up that has a place to browse your computer for the picture you want to post. You can do up to 5 per post. If they are too big you get a message telling you so. Close the window, preview the post to make sure they look like you want them too. If its good to go then "submit reply".
OrrieG is offline   Reply With Quote
Old 12-10-2008, 11:14 PM   #9
63 & 64 Bowties
and a few others
or just open a free account on photobucket.com and use the link feature.
after you upload your picture to photobucket, click on the picture, choose HTML code, right click, copy, then right click here, paste it to your message. done
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-11-2008, 08:04 PM   #10
junkman1jmc
i have a photobucket acc but i get a error mess when i try are they to big?
Old 12-11-2008, 10:36 PM   #11
junkman1jmc
i have a ? is a camaro subframe the right width for a 48 gmc?????? the reason i asked is a guy offered me a camaro subframe for my stright axle front end . should i swap with him??????????/
Old 12-11-2008, 10:39 PM   #12
55dude
55dude's Avatar
to wide unless its out of a 67'-69' camaro and those usually dont have disc brakes. 70'-81' is too wide.
55dude is offline   Reply With Quote
Old 12-11-2008, 10:41 PM   #13
junkman1jmc
so i might as well use the s10 frame
