Old 11-26-2008, 12:03 AM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Gen III Question
If you install an LS- based motor, but you use a carb'd intake, what do you do for a fuel pump? Is there on on the motor?
On a side note, how much power can the stock gas tank support? Is it limited by anything?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 11-26-2008, 12:09 AM   #2
463
463's Avatar
Re: Gen III Question
you would use an electric fuel pump (low psi pump)
Trueman
463 is offline   Reply With Quote
Old 11-26-2008, 12:10 AM   #3
Ackattack
Ackattack's Avatar
Basically you run an electric fuel pump. They have fuel pumps that put out low pressure for carbs, I'd still run a regulator though.
They do make a front mount distributor set up that also allows you to run a distributor, but it's VERY spendy.
Ackattack is offline   Reply With Quote
Old 11-26-2008, 12:24 AM   #4
LuckyHenriksen
Ok so it just needs an electric pump. Would that be in the tank or inline?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 11-26-2008, 01:02 AM   #5
Ford Assassin
Ford Assassin's Avatar
Inline.
I've never heard of a low pressure in-tank pump, but I could be mistaken.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 11-26-2008, 01:10 AM   #6
danman987123
danman987123's Avatar
i have a aluminum tank under the bed...it does have pump inside..not to high pressure just stock 40-45 psi...i not its not the weakest but dont think its real strong...just needs to supply for my 350 tpi. i know i dont got the big daddy LS but just my lil bit of info
danman987123 is offline   Reply With Quote
Old 11-26-2008, 01:19 AM   #7
Ford Assassin
That is extremely too much pressure for a carb. It needs to be in the 5-7 psi range at best.
Cable
Old 11-26-2008, 01:24 AM   #8
LuckyHenriksen
Ok so if I put a fuel tank under the bed, I just put a pickup in the tank and an inline pump outside?
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 11-26-2008, 01:35 AM   #9
Ford Assassin
Correct and as close to the tank as possible.
Cable
Old 11-26-2008, 01:44 AM   #10
LuckyHenriksen
Alright sweet, thanks for the info. Im taking notes and making plans ;D
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 11-26-2008, 01:20 PM   #11
Hart_Rod
Hart_Rod's Avatar
You could use an in-tank TBI pump. It has an output of 12-14 psi. You will still have to run a regulator to drop it to 4-7 psi.
Hart_Rod is offline   Reply With Quote
