Old 11-26-2008, 12:11 AM   #1
badriand
badriand's Avatar
Rear shocks?
Got 5 ich drop on back, you guys running drop shocks or has anyone found some stock ones that work fine? Right now , i am just using stock.
badriand is offline   Reply With Quote
Old 11-26-2008, 11:20 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Rear shocks?
How is your rearend lowered? Lowering blocks, shorter springs, etc? I set up my buddy's '66 (shorter springs and 1-inch blocks) with a set of OE-type Monroe oil-filled shocks that are normally for the front (since they are a little shorter).
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-26-2008, 07:30 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: Rear shocks?
Igot a kit and it came with doestch tech's. I like them as they control rebound well.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-26-2008, 09:23 PM   #4
1restorick
1restorick's Avatar
Re: Rear shocks?
I lowered my truck 5" in the rear and used the KYB gas shocks from ECE along with the relocator brackets. Sorry I don't have a photo of the shocks only the truck. It rides super nice.
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 11-27-2008, 12:14 AM   #5
badriand
badriand's Avatar
Re: Rear shocks?
Where do the relocator brackets mount to? Got a c-notch on the back, with 5 inch drop coils.
Old 11-27-2008, 01:31 AM   #6
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Rear shocks?
I'm using a 4" spring with this shock relocator kit.
I've got the shocks all i know is they are KYB. I can try to find a part number if needed. I'm also running a Super track bar.
Alan's Classic is offline   Reply With Quote
Old 11-27-2008, 08:34 AM   #7
1restorick
1restorick's Avatar
Re: Rear shocks?
The shock relocator brackets attach just like your stock brackets. You will have the fun job of removing those "pesky" factory rivets. the upper brackets then mount up with grade 8 fasteners (included) and the lowers bolt to the rearend using the factory u-bolts. They place the shock at a more direct angle in relation to the suspension travel and really improve the ride. The KYB shocks are firm, but not a punishing ride. Best of luck.
Rick
RED RUMBLE
Owned since 1984
