Old 11-26-2008, 01:34 PM   #1
slepysal
slepysal's Avatar
POWER STEERING , how long?
I wanted to do my power steering swap this Friday, and wanted to ask those who have done it about how long "should" it take?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-26-2008, 01:52 PM   #2
LILRED66
LILRED66's Avatar
Re: POWER STEERING , how long?
It all depends on:
your skill level
if you have all the correct parts
the tools you have
I have done several power steering conversions on 4-5-6 Chevy trucks and it can be done in a long afternoon. If all goes well, it can be done in 6-8 hours.
Surely, someone will chime in and say they can do it quicker, however I am not trying to win a contest to see who is faster, I just know how long it usually takes me.
LILRED66 is offline   Reply With Quote
Old 11-26-2008, 02:02 PM   #3
slepysal
slepysal's Avatar
Cool LILRED.
I wanted to know if it could be done in a day , and who beter to ask then those who have done it. Im still debating on using my tilt or wating to do it when I re wire thanks
Old 11-26-2008, 02:29 PM   #4
steverino66
Originally Posted by slepysal View Post
Cool LILRED.
If you have the tilt column that matches your power steering box, that may save you some grief - already the correct length/connections
steverino66 is offline   Reply With Quote
Old 11-26-2008, 03:04 PM   #5
joe231
joe231's Avatar
yeah it all depends on what parts you are using. I did our '66 in about the time frame Tony is saying, i used factory p/s steering brackets, had to raise the engine slightly to install them. I had to do some frame welding. found some cracks under the manual box. The truck already had the newer cross member and steering components. I did use the stock column, so I had to cut it down and weld it. oh and it takes a little bit of time to bleed the air out of the system also.
it is very do-able in a day
CHEVY ONLY
Old 11-26-2008, 04:55 PM   #6
slepysal
slepysal's Avatar
Great !! I have the pump already instaled, and the p/s kit from CPP for my year 1960, hoses,belt and gear.
I'll post pics thanks again
Old 11-26-2008, 07:27 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
It goes easily enough; I had my whole front end apart so no idea about the time frame. I thought the hardest thing would be shortening the steering shaft and even that turned out well.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-27-2008, 01:22 AM   #8
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
a good days work.. You got the newer tilt so everything should line for you easy..
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 11-27-2008, 01:26 AM   #9
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
It's taken me a year and a half and I'm not half way done yet.
Alan's Classic is offline   Reply With Quote
Old 11-27-2008, 08:54 AM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Wait a minute...I thought you had P/S already ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-27-2008, 03:20 PM   #11
slepysal
slepysal's Avatar
I have the pump installed, but have not got around to installing the box, hoses and fixing the steering shaft
Old 11-27-2008, 04:09 PM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I thought I seen a P/S pump on your sixer at the Alum Rock gettogether last time ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 11-27-2008, 08:48 PM   #13
ENHANCED AIR RIDE
I've done a few 60-66s. Just did a 62 with the 250 3 on the tree. That one was a PITA. Definetly doable in a day as stated depending on what all you want to do, ie column etc.
ENHANCED AIR RIDE is offline   Reply With Quote
Old 11-27-2008, 08:52 PM   #14
ENHANCED AIR RIDE
after
Old 11-27-2008, 09:55 PM   #15
jmedero
jmedero's Avatar
ok help the new old truck guy out with a question. Why is your ps pump behind that other item in your engine bay? Every one I have ever seen is on its own bracket off of the belt drive track. Thanks and sorry again for the rookie question.
Juan
jmedero is offline   Reply With Quote
Old 11-27-2008, 10:09 PM   #16
jmedero
jmedero's Avatar
Juan
Old 11-27-2008, 10:24 PM   #17
slepysal
slepysal's Avatar
yea I had the pump mounted but not hooked up.
ok here is an up date. Old gear is out ,addapter and new gear mounted, steering shaft is cut.
As allways, I did run into a few problems, old pitman arm needed a lot of coaxing to get it out. 2nd ,the addaptor plates instructions were a bit "off" it said to drill out the lower front bolt hole on the new gear, I found out that on the 60 I had to drill out the upper hole on the rear. And 3rd my pitman arm on the donor gear is not leting me tighten it up, so I'll get a new one tomorow
That said it wasnt bad I still need to install the hoses, and get one bolt to finish mounting the box. I also need to install the steering shaft, and get that pitman arm and bleed it .
I know I said i was going to do this Friday but who wants to watch the Lions play? anyways I took some pics, and will post them when all is done. Thanks to all who said it was an afternoon job it is.
Old 11-27-2008, 10:40 PM   #18
MEANlowGREEN
Registered Asphalt Offender
MEANlowGREEN's Avatar
Originally Posted by LILRED66 View Post
It all depends on:
your skill level
the tools you have
I did mine in 19 minutes 17 seconds! Just kidding, LilRed66 is probably pretty close to an average time it would take providing you have the correcct parts, tools and a fair amount of skill. I'd think the average competent DIYer could do it in an afternoon.
It's not too low unless the tires won't reach the ground anymore!
1963 C10 Short Fleetside Bed Big Back Glass
1974 C10 Short Stepside Bed
1982 S10 Shortbed 350 EFI V8
http://67-72chevytrucks.com/vboard/a...hp?albumid=140
http://www.hubgarage.com/mygarage/MEANlowGREEN
http://www.motortopia.com/garage/cars/MEANlowGREEN
http://www.myspace.com/jcsmeed
MEANlowGREEN is offline   Reply With Quote
Old 11-28-2008, 01:30 AM   #19
ENHANCED AIR RIDE
Juan
Hello Juan
That is a rare generator/power steering unit from the tri 5 chevys. I believe it came on 58 and 9 cars too. The p/s pump and brackets for the 250 "stovebolt's" are like hens teeth to find. I did find a set of brackets for the 250 but decided to use this instead since I found a rebuilt unit fairly inexpensive. Had to custom make the mounts and rebuild the generator. Worked awesome!!!
Old 11-28-2008, 10:49 PM   #20
slepysal
slepysal's Avatar
well like always, something came up. I need to replace the pitman arm, but I didnt want to wait to get one from work on monday, so I orderd it from a local parts house.
It will be in at 11 am they told me . So in the mean time I installed the hoses, worked on the steering shaft, and finished installing the box.
I called to see if my pitman arm had come in,nope. The driver left it at the wharehouse, It will be in at 12:30 , so I waited . At 12:30 I get a call "your BALL JOINT is in , yup ball joint..... So now I have to wait till tomorow.
any ways any tips on installing the pitman arm ?
Old 11-30-2008, 12:49 AM   #21
slepysal
slepysal's Avatar
all done !! I will post pics soon
Old 11-30-2008, 11:10 AM   #22
Chevy Fleetside
Chevy Fleetside's Avatar
cool....
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-30-2008, 11:14 AM   #23
joe231
joe231's Avatar
well....you know what is coming........
CHEVY ONLY
Old 11-30-2008, 10:29 PM   #24
slepysal
slepysal's Avatar
yea yea yea.................
here are the components and new gear
and the old gear
Old 11-30-2008, 10:38 PM   #25
slepysal
slepysal's Avatar
the old gear is out, no problem with the frame......
the addaptor plate installed
