Old 11-26-2008, 04:54 PM   #1
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
Calling all turbo guys
ok, my truck is almost done and ive been wanting to add more power. my and my dad are going to do a cam kit in the near future, but i think it can handle more. ive seen a few guys on here that have a twin turbo setup. so what im askin is what all do i need to do this. ive seen the headers on ebay that run off the exaust, thats what i need right? can any turbo work like one from a newer truck? do i need to make a metal box to go around the carb? any help?
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
Old 11-26-2008, 05:02 PM   #2
jrsmith_2010
I like turtles...
Re: Calling all turbo guys
heres the headers i found
http://cgi.ebay.com/ebaymotors/Small...Q5fAccessories
Old 11-26-2008, 05:30 PM   #3
C-10volvo
C-10volvo's Avatar
Research research research!!!!
There is a lot more to it than just buying exhaust manifolds, turbos and tubing. A lot of times, it will require a full rebuild of the motor with strong forged short block with lower compression pistons.
To answer your question: yes, the carb will need to be enclosed.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 11-26-2008, 09:17 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
like c10volvo said, this is more than just slapping a set of manifolds and bolting on the truck with some turbos.
Ideally you want to match the turbo to the power level/displacement/etc.
How was the engine built? will it handle the added stress? If it is stock, don't expect to boost it more than 5lbs, which would be a waste in my opinion, unless you just want to play around with experience.
A carb has to be modified to run a blowthrough setup, and you HAVE to have an blower hat/enclosure.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-26-2008, 09:27 PM   #5
trixter99
I have no time for this
trixter99's Avatar
Save your money and put it to better use. Twin turbos are way beyond your needs.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 11-26-2008, 09:44 PM   #6
jrsmith_2010
I like turtles...
what would be more ideal, turbos or supercharger? thanks for all the opinions
Old 11-26-2008, 10:13 PM   #7
trixter99
trixter99's Avatar
I f you are just wanting something cool and practical buy a supercharger.
2009 Gmc 2500 HD
2007 BMW X5 Sport
Old 11-26-2008, 11:25 PM   #8
jrsmith_2010
I like turtles...
im lookin just for something that will sperate my truck from all the other square bodys in my town, something to outrun them if needed
Old 11-27-2008, 12:10 AM   #9
C-10volvo
C-10volvo's Avatar
If speed is what you're after, do the cheap things first. We need to know what you have in your truck at the moment to give you better suggestions.
Ken Morgan
Old 11-27-2008, 12:49 AM   #10
jrsmith_2010
I like turtles...
its a stock GM crate motor with 194 heads
Old 11-27-2008, 01:48 AM   #11
BigAl
Can you actually have a turbo with a carb? I can't concieve of it...
Anyways, sounds like supercharged is a better option...
BigAl is offline   Reply With Quote
Old 11-27-2008, 02:03 AM   #12
jrsmith_2010
I like turtles...
well me and my dad where talkin about what we can add to it before the forced injection. like a cam kit, some 2.02 heads, but what else can i add for added horses?
Old 11-28-2008, 02:33 PM   #13
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
The carb doesnt absolutely need to be enclosed, but it does need to be modified. With the enclosure you can run a relatively stock carb provided you have a boost referencing regulator and enough fuel pump to push the fuel into a pressurized box. The drawback to the enclosure is getting to the carb to do some tuning, you will have more work involved with any changes you make to the carb.
With the hat only no enclosure, tuning is easier but the carb needs to be modified so pressurized air doesnt go places it shouldnt, as well as so that it flows enough fuel to keep the engine happy.
Centrifugal superchargers also can use a blow through carb with either method of getting air into the carb. The roots style blower is the one with the carbs mounted above the blower, and they fit pretty well under the hood of a square. I would like to drop one on the 454 in the 76 for some fun and puling power.
The engine will need to be able to take higher cylinder pressure, not so much higher rpm. Usually the weak link is the head gasket, but go lean just once under load and you will have pistons that look like Laquechia's hoop earrings. When tuning and setting up a turbo system, you cant just slap stuff together, you have to know or have someone who does know what they are doing help you, without knowledge you will just burn money and break parts. Study first, build second, make power last.
Not only does the engine need some upgrades, the fuel system needs them as well. Your stock mechanical pump isnt going to get the job done. You will spend around $1000 for the basic fuel system but you can easily spend a bunch more. More air means more fuel, its as simple as that.
Here are some blow through systems that dont use the enclosure. Its more often you see this setup than the box due to the ease of changes to the tune.
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 11-28-2008, 02:42 PM   #14
LMDGUY
LMDGUY's Avatar
turbos are alot of work and expennce upfront but you do get sum good power.. search online for a forum call "turbo mustangs" lot of good tech and info.. not just mustang info also
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 11-28-2008, 11:04 PM   #15
Captkaos
Captkaos's Avatar
This is a link to all 8 of the CHP articles they did on building up a crate motor:
http://forum.73-87chevytrucks.com/sm...p?topic=8639.0
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-30-2008, 09:30 PM   #16
jrsmith_2010
I like turtles...
ive been lookin into the 671 supercharger, ive seen all kinds of different prices, what is the ballpark for one?
Old 11-30-2008, 11:12 PM   #17
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
How about a carb with twin turbos!!
http://www.turbocustoms.com/index.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-01-2008, 12:11 AM   #18
jrsmith_2010
I like turtles...
been doin some research, and a 671 supercharger is about 2500, so i found a turbo kit one ebay, for a camaro.
http://cgi.ebay.com/ebaymotors/CHEVY...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
but how would this be hooked up?
Old 12-01-2008, 12:59 AM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by jrsmith_2010 View Post
been doin some research, and a 671 supercharger is about 2500, so i found a turbo kit one ebay, ......
Just follow the simple to read step by step instructions.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-01-2008, 03:34 AM   #20
mickman77
mickman77's Avatar
was on the vortech site researching a supercharger for my '06 K 2500 HD and it looked simple enough with great reviews about clear and precise instructions. might be worth a peek.
mickman77 is offline   Reply With Quote
Old 12-01-2008, 09:19 AM   #21
jrsmith_2010
I like turtles...
so even tho the turbo kits are for a camaro, its all compatible for a 350 for my truck right?
Old 12-01-2008, 09:48 AM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
It's compatible in the sense that it for a small block Chevy motor. Beyond that, no it's not going to fit. No one makes a "kit" for your truck. Your going to have to custom build one from scratch.
Speaking of scratch, have you considered what this will cost?
If you really want to make your truck unique, stay focused on making it nice. I'll bet that most of the trucks running around are in need of cosmetic upgrades. If you focus on having a good running truck that is really detailed it will stand out from the crowd.
Articles-
"Refining Sierra"
Old 12-01-2008, 02:42 PM   #23
jdurant
Yeah dude, bad idea. To make a turbo setup worthwhile on your motor would really cost big bucks and you would basically have to start over from square one to do it right. Money would be much better spent elswhere. A Blower, nitrous, or machine work+more aggressive heads/cam/compression would be a better options, but an LSx is hard to beat bang for your buck. Now if your dead set on forced induction: get an LC2-with a few performance parts you can make 500hp and get 20mpg but you would have to tell people there is a Buick 6 cylinder in there. That would be different.
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 12-01-2008, 05:44 PM   #24
Albatrossian
Georgia Boy
Albatrossian's Avatar
I've owned several turbo cars before.. 2 Turbo Coupes and a turbo'ed 92 LX Mustang. All 3 of those cars needed forged bottom ends(crank, rods, pistons) to live. You'll need to run a cam with more lift on the exhaust side. Also, running a turbo with fuel injection is far easier to tune, but more costly. Your whole fuel system will need to be upgraded to eat least able to push 100psi of fuel pressure. Then factor in the cost of turbos at $600 each new, blow off valves for each, wastegates for each and an intercooler big enough to handle two turbos. Yes, they can make ALOT of power and still be very streetable, but they aren't cheap. I would focus on making your existing engine as strong and reliable as you can while making power too.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 01-06-2009, 12:23 AM   #25
71/454
Turbo Guy
71/454's Avatar
It can be done, it's not that expensive. Everyone is right, look at what you want achieve and research, research, research. Turbo's do require a bit of fabricating skills, welding pipe fitting etc. Someone suggested visiting the turboforums.com, this is a very good idea before you start.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
