11-27-2008, 01:47 AM | #1 |
Another Gen lll Question
What oil pans work in our trucks?
Nevermind I searched harder and found some info. But still have ?'s I hear of the Caddy CTS-V pan being used, also the stock truck pan. Which works best? Also which motor mount location works best? The I6 one or the V8 one? Thanks Last edited by LuckyHenriksen; 11-27-2008 at 01:51 AM. |
11-27-2008, 02:52 AM | #2 |
Re: Another Gen lll Question
Im in the same bus as u are, I've heard if u want to go body drop, the CTS
is the way to go, but if u want to be a regular go with the stock truck oil pan. Show some pics of your Gen III |
11-27-2008, 03:20 AM | #3 |
Don't have one yet, Im in the planning stage. I'll definitely post up tons of pics when I get my s*** together! (Im a pic whore)
So a stock truck pan will fit stock or static drop suspension? How about positioning the motor mount stands? |
11-27-2008, 03:35 AM | #4 |
I heard ECE motor mounts will get the job done
11-27-2008, 03:42 AM | #5 |
great, thanks ill check those out
11-27-2008, 11:31 AM | #6 |
I used the ECE mounts, and am using the stock LQ4 pan with no problems.
Side note, you can't pull the pan with the motor installed though. |
11-27-2008, 12:14 PM | #7 |
As a side note, if i remember shifty's correctly the f-body manifolds fit our frame nicely
ian |
11-27-2008, 12:34 PM | #8 | |
http://67-72chevytrucks.com/vboard/s...=272174&page=2 http://www.ls1tech.com/forums/conver...-oil-pans.html It fits perfect and raises it above the front crossmember.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-27-2008, 02:11 PM | #9 |
Ok cool, thanks for the responses. So either will work, the CTS-V pan just doesn't hang down as far?
And its ok about not being able to pull it without taking the motor out, I can't get my small block's out either. |
11-27-2008, 03:29 PM | #10 |
Here is a pic of my 2007 5.3 with original truck pan. It sits pretty low, i may make a skid plate for it.. I am using performance online tubular mounts.
Trevor Last edited by tk-mpl; 11-27-2008 at 03:30 PM. |
11-27-2008, 03:36 PM | #11 | |
Here's some more pictures:
11-27-2008, 03:53 PM | #12 |
Sweet, thanks for posting up the pics guys. I'll keep an eye out for a Caddy pan! Might have to give in and buy one from a GM dealer.
11-27-2008, 06:10 PM | #13 |
If you have to buy a new one you might as well get a camaro pan new form gm. You for sure don't want a truck pan if your are going to be low.
11-27-2008, 06:14 PM | #14 |
So most if not all of the pans will fit the trucks cross member?
11-27-2008, 07:11 PM | #15 |
That depends on the engine mounts you use. The camaro pan WILL NOT work with the ECE mounts. The truck and the caddy work well with (ECE and the plate type mounts (S&P, CPP, etc), but the truck pan hangs down below the front crossmember. If you're not going very low chassis wise, the truck will work well. If you're slamming the chassis, I would switch to the camaro or the Caddy. I personally like the cadddy one because the oil drain is in the back, but that's just me.........
11-27-2008, 07:41 PM | #16 |
Ok thanks for the clarification
11-27-2008, 07:42 PM | #17 |
If I wanted to use am F body pan, would I need custom mounts?
11-27-2008, 08:05 PM | #18 |
You will have to use some form of modified mounts. The factory ones will not work "as is". R/
