Old 11-27-2008, 01:24 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Exhaust Manifold Bolt Sizes
I have some Ram Horn Exhaust manifolds that I dropped off to get coated and was wanting to coat the bolts too. What sizes are they??
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-27-2008, 03:04 PM   #2
mbgmike
Re: Exhaust Manifold Bolt Sizes
9/16" x 2.1/2" outers
9/16" x 3" inners
I don't swear they are correct for all heads
mbgmike is offline   Reply With Quote
Old 11-27-2008, 03:11 PM   #3
5150
C10 Club Tennessee
5150's Avatar
Guess I should have said, sorry, they are stock 882 heads.
Bryan
www.gmtruckshow.com
Old 11-27-2008, 03:32 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
You'll need 8 thick washers for the outer 4 bolts, the inner doesn't use washers.
If you are going to use the locks then you should coat them too.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-27-2008, 04:01 PM   #5
mbgmike
They should fit without any options/brackets bolted to them.
Old 11-27-2008, 04:21 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Lets's see'um after you get 'em back....now that my engine is out, and a friend gave me three sets of ram's horn manifolds (and two other set...Thanks, Mike), I'm thinking I might not want to reinstall the Hooker headers that came off of the engine.
Member Nr. 2770
Old 11-27-2008, 04:24 PM   #7
5150
C10 Club Tennessee
5150's Avatar
No brackets, I'm running a serpentine setup
Bryan
www.gmtruckshow.com
Old 11-28-2008, 11:47 AM   #8
jaros44sr
jaros44sr's Avatar
Got new ones for mine at Corvette America, not sure if all bolts are created equal when it comes to exhaust manifold bolts. Thought I read on here that they are special in some way
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-28-2008, 11:58 AM   #9
Cyclone
Cyclone's Avatar
9/16" x 3" inners
Just to clarify....
actual bolt thread size is 3/8"-16, bolt head size is 9/16"
Cyclone is offline   Reply With Quote
Old 11-28-2008, 12:07 PM   #10
mbgmike
Originally Posted by Cyclone View Post
Just to clarify....
OOPS
thanks for the correction
Old 11-28-2008, 03:54 PM   #11
5150
C10 Club Tennessee
5150's Avatar
That's the only thing I WAS sure of
Bryan
www.gmtruckshow.com
Old 12-18-2008, 04:10 AM   #12
Rack Man
Actually....those are not the correct lengths for my stock 350....I just went through this...I initially used the 2.5" & 3" lengths, but I wound up bottoming out in several of the holes before they tightened....
I then ordered a correct kit from one of our site vendors and they came in 8 ea. @ 2.25" & 4 ea. @ 2.75" (centers).....they were perfect!
It's my understanding that you do not ever want to bottom out like that as you can cause major damage...
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 12-18-2008, 06:39 AM   #13
northern 85
northern 85's Avatar
What is the grade # of the bolts?
northern 85 is offline   Reply With Quote
Old 12-19-2008, 07:15 PM   #14
mbgmike
Dan
Yeah the manifolds must be differant cause I pulled the bolts on a stove stock 350 with stock manifolds also just before I posted the lengths
