11-27-2008, 09:05 PM | #1 |
Watch out for your cornhole !
Hey fellas, look at this truck and see if you see what I do
http://cgi.ebay.com/ebaymotors/Chevr...QQcmdZViewItem
The seller goes into long detail about the truck, but I think he left out the biggest modification. Am I seeing things or is there something going on here ? The truck looks like a heck of a deal for 8k. Big block, gear vendors OD unit, rebuilt rearend by Randys, on and on. Very well built. Looks like he pulled no punches on the build and went all the way.
11-27-2008, 09:08 PM | #2 |
Re: Hey fellas, look at this truck and see if you see what I do
The stretched cab they should have stretched the doors too
11-27-2008, 09:14 PM | #3 |
I have a radical idea!
Besides the cab, he states several things about a TH400 with a GV OD unit, but the truck has a 4 speed shifter. It has no clutch pedal, and a Lokar shifter in the floor. I can't figure out what the 4 speed shifter is hooked up to though???
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
11-27-2008, 09:18 PM | #4 |
Wow, good eyes
'68 chevy c10 1/2 ton inline 6, 250 2wd stock everything. exposed to elements for 40 years '87 Dodge D150, 318 auto stock; D.D. God meant for rubber to be burnt, not for an ear of corn Myspace |
11-27-2008, 09:22 PM | #5 |
Step Brother
I would like to see how it is finished on the inside....
11-27-2008, 09:41 PM | #6 |
laying low
He states it was bought at Barrett Jackson a few years ago. It must be pretty nice then. That extra few inches of cab depth sure would be nice.
$20,000 all day long I think is quite a stretch but he'll sell it now for $8,000. ? I like it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-27-2008, 09:43 PM | #7 |
does the OD have a shifter? never seen one before.
if not then I would say its a trans parking brake? Is that a large window?
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
11-27-2008, 09:43 PM | #8 |
its all about the +6 inches
I wonder if the tall one is the locar shifter (made to look like a 4 speed) and the other lever is a PTO of sorts? There is a lot left out of the description... aftermarket heat and a/c is normally a bragging point when selling.
11-27-2008, 10:02 PM | #9 |
I don't know seems fishy. I am not the trusting type.
11-27-2008, 10:12 PM | #10 |
The tall shifter is the Lokar shift handle http://www.lokar.com/product-descrip...ia-shifter.htm
While the one beside it is a emergency brake handle http://www.lokar.com/interior_pages/...rake_frost.jpg. Again I think that is also Lokar. Note that in the interior view from the passenger side you don't see an emergency brake pedal or handle over on the far side of the steering wheel. There have been times when I wished I had a couple of extra inches of leg room and the bucket seats almost require a longer cab interior to work but I agree that it would have looked better with the doors stretched. Last edited by mr48chev; 11-27-2008 at 10:17 PM. |
11-27-2008, 11:12 PM | #11 |
Son of a gun
That second lever is an emergency brake.
Bill BEATERS ARE NEATER |
11-27-2008, 11:14 PM | #12 |
That's a sharp truck. I like the stretched cab.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-28-2008, 12:36 AM | #13 |
After a little more looking, it is a '67 cab (you can tell by the ashtray and the ignition key) , so I wonder if it was a small rear window cab that was stretched and had the large window added. It appears that the bed was designed to replace a standard 8' box, and if it was, there would be a 6 inch gap because the 1 tons had a 6 inch longer 133" WB. Maybe the cab was stretched to take up that space. The fuel tank was obviously moved since the filler neck is gone, and it appears the seats set a little further back than the factory one would have been. I don't necessarily like the look of it, but I imagine that extra leg room and maybe even a little behind the seat storage would be nice.
Also, if I had it, I'd add a set stainless trim rings like I did on my '67 C-30. It makes the wheels look totally different.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 11-28-2008 at 12:40 AM. |
11-28-2008, 12:49 AM | #14 |
3DrDwn--the 'burb not the band
I'm wondering where the switch for the GV unit is. On my K-30 i have a big red button on a switch clamped to the top of the shift lever just below the knob. I have seen 2 speed rear ends and commercial trucks with similar switches. with it mounted anyplace else ( and i looked and didn't see anything looking like a GV switch in any pics) I think it would be very dificult to engage while driving and shifting especially when splitting the gears.
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
11-28-2008, 01:02 AM | #15 |
Could it be that the cab actually was a camper type of RV that was open originally then modified to what it appears to be now. Thinking 72rs/ss had a cab from something like that and was completly open and needed a cab back to make it a pick up cab. Just a thought!
The biggest problem people have, is other people Thou shalt be cool and not hassle Be a site supporter. The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
11-28-2008, 01:04 AM | #16 | |
11-28-2008, 01:06 AM | #17 | |
11-28-2008, 01:23 AM | #18 |
who knows they could of add any thing on that truck it could be more than one year on some of the parts
11-28-2008, 01:30 AM | #19 |
but that 454 engine is not right engine for 67 well its being a one ton truck the right engine would have been a 292,283,327
11-28-2008, 07:37 AM | #20 | |
67 C-30, The second dimmer switch is a common Gear Vendors switch location, so I'd bet that's what it is.
11-28-2008, 12:39 PM | #21 |
Next project: 1970 K10
The VIN is confusing to me, CE337Z140193.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
11-28-2008, 02:35 PM | #22 |
I saw the truck @ the AZ GoodGuys show last year. It was in the swap meet area & caught my attention from quite a distance away. Looked pretty solid then but I wouldn't purchase a stretched cab w/o reference pics of/during the build.
The bed set-up was clean.
11-28-2008, 05:08 PM | #23 |
CE337Z140193
C 2 wheel drive E V8 3 one ton 3 cab/chassis (no bed) 7 1969 Z Fremont (cali) build plant 140193 #40193 built on that assembly line at that plant for that model year |
11-28-2008, 06:48 PM | #24 |
Interesting set-up, Could be a nice tow rig. Not bad for that price.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
11-28-2008, 07:11 PM | #25 |
Exactly. A decent 454, TH400, Gear Vendors OD unit and freshly rebuilt rearend is worth a mint alone. The nicely done modifications to the bed and electrical system are a nice bonus too.
