11-28-2008, 04:55 AM | #1 |
2wd 4spd
I have a 2wd 72 c10 with a 4spd. Is this considered a sm465?thanks
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
11-28-2008, 06:51 AM | #2 |
Re: 2wd 4spd
It is probably a SM465 or an SM420. I am not sure when they changed from SM420 to SM465 and I forgot the visual markers that determined which was which.
It won't take long for someone to check in and answer your questions for sure. |
11-28-2008, 07:54 AM | #3 |
Re: 2wd 4spd
Not a 420. It is a 465 or a very slim chance that it is an NP435.
Tim |
11-28-2008, 01:37 PM | #4 |
Re: 2wd 4spd
so is it useble if I convert to 350 and convert to 4x4?
12-01-2008, 12:42 PM | #5 |
Re: 2wd 4spd
usable, yes. easy, no. the tails & outputs are different between the 2WD & 4WD tranny's. you could run a short jack shaft to drive a x-fer case if you were hell bent on using that specific tranny.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
