Old 11-28-2008, 11:07 AM   #1
69Rob
69Rob's Avatar
Drop blocks?
Does any one know where i can buy lowering drop blocks from? i found a pair on ebay but for $100 i was told that they should cost under $50 for about a 2" drop
2009 dodge hemi custom paint
86 lwb bagged layin frame
73 2 door nova
54 bel air
69Rob is offline   Reply With Quote
Old 11-28-2008, 11:18 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Drop blocks?
I make my own out of 2 inch square tubing. I did an FAQ article on the whole process if you care to search for it.
Old 11-28-2008, 11:20 AM   #3
Tx Firefighter
Re: Drop blocks?
Here:
25 bucks and a lot of satisfaction from doing it yourself...
http://www.67-72chevytrucks.com/vboa...ghlight=blocks
Old 11-28-2008, 11:25 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Drop blocks?
This is the method I used worked great..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-28-2008, 11:48 AM   #5
69Rob
69Rob's Avatar
Re: Drop blocks?
Wow thats nice looks easy enough now i got to try and find the time and tools to do it. wouldnt want to make a pair and ill buy them off you would ya?
73 2 door nova
54 bel air
Old 11-28-2008, 11:58 AM   #6
bdydrp97s10
bdydrp97s10's Avatar
Re: Drop blocks?
this is what i did..
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 11-28-2008, 12:08 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop blocks?
Looks like the block was 7" long. Does anyone know the "center to center" length of the u-bolt holes? Also what size holes to drill? (I think I drilled mine 7/8",... but I cant remember.
Keith
Convert to disc brakes.
Old 11-28-2008, 12:17 PM   #8
bdydrp97s10
Re: Drop blocks?
i made mine last week... the center to center of the hole is 4.25 inches.. and i drilled a 7/8 hole
Old 11-28-2008, 12:40 PM   #9
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Drop blocks?
I dont know the measurements or the size to drill the holes. but if you have the original shock mounts you could get the measurement off those.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-28-2008, 12:49 PM   #10
lolife99
lolife99's Avatar
Re: Drop blocks?
Thanks for the quick replies.
Keith
Old 11-28-2008, 01:56 PM   #11
my67chevytruck
Under Construction
Re: Drop blocks?
let me know if you dont have any shock mounts available to measure. PM me and i can go look through the parts in the garage(have some somewhere) and get you some measurements.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
