11-28-2008, 02:11 PM | #1 |
Grandpa in the rustmobile...
removing 68 dash panel.. !QUICK?
OK, Im trying to remove my dash panel on my 68..and i cannot figure out how to remove the headlight/windshield wiper knobs..ive lostened the nut on them, but cant figure out how to take the black knob off...and how do you unplug the guages from behind the dash? thanks!
Im goin to trace it out on cardboard/paper and eventually do it in diamondplate...alum. etc thanks again-John, and im back outside tryin to get it off
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-28-2008, 02:18 PM | #2 |
Re: removing 68 dash panel.. !QUICK?
Usually there's a button on the switch itself that releases the knob and the shaft.
11-28-2008, 02:36 PM | #3 |
Watch out for your cornhole !
pull the lights into the on position, Then push the button on the back of the switch, and pull the knob out of the switch.
11-28-2008, 03:24 PM | #4 |
72 chevys 4 life
yup and the wiper knob just has a lil set screw on it...
I dont call it being young and dumb....I call it young and havin fun |
11-28-2008, 04:10 PM | #5 | |
Next project: 1970 K10
And once you have those out and the bezel unscrewed from the dash, you can then pull the complete bezel out and unplug the wire harness. There is a tab on each side to press in then it pulls straight out.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 11-28-2008 at 04:12 PM. |
11-28-2008, 06:57 PM | #6 |
Even easier is to unscrew the speedo cable. Unscrew the steering wheel housing on the bottom of the steering column. Then you can undo the oil pressure line. and the whole dash will come out.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
11-28-2008, 07:23 PM | #7 |
alritey, well i gave up and worked on somethign else, but in the next few days when i get the chance again i'll try that^
thanks, wow this sites great
11-28-2008, 10:20 PM | #8 |
72 chevys 4 life
yeah and your dash wont quite pull out until you unhook the oil pressure line...and like 72army said that bolt on the steering wheel housing makes it 999999 times easier to get the dash out...
01-08-2009, 03:01 PM | #9 |
OK I had the same prob as oldblue68, I got it, now how do I remove the choke and throttle? there's no screws or buttons, when I unscrew the nuts at the gauge face are the cables supposed to come all the way out? all together. my truck is a 67 c10
Check out my Photos http://67-72chevytrucks.com/gallery/...ry.php?cat=769 L.L. N.M. 63 chevy c-10 67 chevy c-10 71 chevy Blazer 4x4 |
01-08-2009, 03:06 PM | #10 | |
Resident Curmudgeon
Choke knobs and 67-70 throttle knobs are threaded, they screw off. 71/72 Throttle knobs use a set screw similar to the wiper knob.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-08-2009, 06:51 PM | #11 |
Who's got steelies?
Easiest way to remove choke throttle knob is to pull it out slightly, and then grip the shaft with some small pliars and turn the knob so it unscrews. You might have to pull the knob slightly as you unscrew it.... I had to do this once because someone screwed it down too tight & stripped it.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
01-08-2009, 10:39 PM | #12 |
Resident of Here
How did you find out? Was there a leak in the system?
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-09-2009, 09:05 PM | #13 |
ok thanks I'll try that for sure,
