Old 11-28-2008, 04:46 PM   #1
BHRS
BHRS's Avatar
Modern Technology 101
I just spent 3+ hours working on my wife's '03 GMC Yukon. I tried to fix it myself and save some money... Well, I did-sort of. On these modern electronic pieces of junk all the gauges are electronic and have known defects ( I learned after the warranty was up). They have little stepper motors which fail causing the speedo to show 110 mph when you are going 20 mph. I researched the "Yukon Forum" to find that this is a known issue and I can buy a set of updated "stepper motors" for $50.00.
I pulled the cluster out and found basically a mother board on a computer. There were more gizmos and solder than gauges. Anyway, to replace the speedo motor I had to pull the needles for all the other gauges and disassemble everything. Since all the gauges use the same motor, I decided to replace them all and be done with it-sounds like a good idea right???
Using the solder gun I heated and removed the speedo motor-simple. I popped in the new one and resoldered it. Next was the tach-this is where I should have just walked away and put it back together... I heated the solder around the four pins bouncing back and forth and pulling on the motor to pull it from the circuit board-it doesn't want to move. I keep heating and pulling until it comes off. Well, I guess I used too much heat for too long and where I needed to solder the new motor to and it melted away. Now the circuit is buried in the plastic of the board. I tried everything I could to fix it, but now the tach doesn't work.
I did heat and remove all the other motors and installed the new ones with no other issues. I put the plastic mess back together and everything works except for the tach. It isn't the end of the world, but I like everything to work right.
Then my wife comes out to see how "her" car is coming. I explain the situation and she tells me "See, this is why I'd rather pay to have someone fix things." I told her we should sell it and buy a '72 Suburban to match my truck then I can work on it. Well, now I am upset with her, the Yukon, and it's raining...
I think I am going to head back to the garage, listen to some country music, and drink beer...
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 11-28-2008, 05:05 PM   #2
airdale94
airdale94's Avatar
Re: Modern Technology 101
It must be the body style, I know the Escalades are the same way. Just tell your wife that's "her toy" and if she doesn't want something "sensible" like a 72 Burb., she can pay to have it worked on. No shame in not wanting touch a mess like that.
airdale94 is offline   Reply With Quote
Old 11-28-2008, 07:46 PM   #3
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Many-moons ago, about 480 of them, in fact, when I was a twenty-something fresh out of school, I went to work for Union Carbide Corp - a plastics films & resin manufacturor.
One of the old-timers had a rating-system for stuff we were testing:
"CPS" in his ratings stood for cheap plastic s _ _ _.
(I'll leave the fill-in the blanks to your imagination).
Took me a while of being there before anyone clued me in.
Sounds like that dash unit would qualify for a definite "CPS" rating.
68shortstep is offline   Reply With Quote
Old 11-29-2008, 10:01 PM   #4
dailydragger03
dailydragger03's Avatar
I think I am going to head back to the garage, listen to some country music, and drink beer...[/QUOTE]
I feel your pain. Just went through the same ordeal. Only I took mine apart and decided not to screw with the motors and I have a friend at the dealership who hooked me up on a new one. Don't sweat it the country music and beer will help.
03 ext cab stepside silverado bagged on 20's with some other cool stuff (daily driver)
1970 c10 short step just gettin started on it (project)
dailydragger03 is offline   Reply With Quote
