Anyone Running 15x10 Front & Rear
Wondering if there are any issues with clearance on the front. Post up your pics if you have them.
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES ![]() 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
Enjoying left field
Re: Anyone Running 15x10 Front & Rear
I'm running 17x10s. 275/50 17s on my 70. In stock form I didn't have any issues. But when I put dropped spindles and disk brakes on it, it pushed the front tires out about 1.5" on each side. check out my build thread for pics.
I've got 275/60/15s on 15x10 wheels on all 4 corners. Disc brake conversion in front and 3" drop springs all around. I've never rubbed anything with the tires.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
Thanks Guys
Chevymad, That's the same set up I'm looking at. Do you have any pics? Woodwright, was it necessary to narrow your xmember because you're running 17's? I really have no interest in doing that. I'd just stick to my 15x8's. I have a chance to get some nice 10's with tires on the cheap. I've got the stuff to do the disc swap (thanks garagedude) but if it won't all work together I'll pass on the rims.
This appears to be the best pic. I'd take a more current one but the truck is apart for paint at the moment. The wheels have a 4" backspacing. But if I'd known that the disc conversion would move them out an inch i'd have used 5" on the front instead. With drums and a 69 rear the 4" is even with the fender lip. The newer width puts them just outside the lip. We've run this truck on this same size wheel/tire combo since 86. But used to have slots on it.
Here is mine!
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
Another pic with 15x10 ralleys.
71 Cheyenne SWB |
Enjoying left field
I narrowed the crossmember because I already had wheels. After I put on all the new spindles and rotors, the tires were out even with the fender lip. The plan was always to bag this one and set it on the deck. This is a farely easy fix if you can order wheels with custom backspacing.
Thanks guys. Picked up the set yesterday from craislist ad. I def have to put my tires on them. He had 265/50's, waaay too short.
70short and xmitsu10 what tire size are you running. chevymad those are very similar to what I got. Thanks Woodwright, not bagging mine just the 3" drop in front. Should look close to 70short's
![]() Join Date: Sep 2005
i am running 15x10 with 255/70 r 15 tires no problems
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#11 | |
71 Cheyenne SWB |
