11-28-2008, 08:18 PM | #1 |
THE TOY STORE
lowering the rear
were can i get longer rear u bolts for my 71 c10 to lower it down? or can i just use two long grade 8 bolts?
11-28-2008, 09:01 PM | #2 |
67-72 parts collector,…
Re: lowering the rear
DO NOT,... I repeat DO NOT use grade 8 bolt. Buy U-bolts to lower the rear. I know a guy that used long bolts on his lowered truck,for over a year, until the rearend came out from under his truck on a corner. Destroyed a beautiful truck. And this guy should have known better.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-28-2008 at 09:01 PM. |
11-28-2008, 09:20 PM | #3 |
Dave's not here, man
Uh, ditto on the above. I bought new u-bolts from ECE and they weren't much IIRC; maybe $30?? I'm pretty sure they have different lengths. You should check with the board vendors. One of those guys should have them. Whatever you do, don't use inferior hardware. You might save now, but you'll surely pay later.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 11-28-2008 at 09:38 PM. |
11-28-2008, 10:00 PM | #4 |
THE TOY STORE
thnx for the info i've never been able to find the larger ubolts for our trucks
11-28-2008, 10:17 PM | #5 |
try the big rig/semi trailer places.
11-29-2008, 02:29 AM | #6 |
most any of the board vendors can help you out.
welcome to the board from Athens, AL |
11-29-2008, 02:44 AM | #7 |
THE TOY STORE
have to check them out thanx.
11-29-2008, 11:20 AM | #8 |
Hey 72hotrodder,... I dug up this old thread. Look like www.stengelbros.com may be the place fore you.
Here's a link to jkade's thread. http://67-72chevytrucks.com/vboard/s...d.php?t=273599
11-29-2008, 11:22 AM | #9 |
Also,... welcome to the board.
I saved this link for myself also. http://www.stengelbros.com/U-boltKits.htm.
11-29-2008, 07:19 PM | #10 |
I had mine custom made for cheap at a local spring shop.
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
