Old 11-28-2008, 08:44 PM   #1
chevys2die4
Junior Member
chevys2die4's Avatar
Original Big Block Engine Info?
I'm looking for more information about Big Blocks in the 67-72 chevy trucks; specifically about the 68. 1968 was the first year for the 396 big block in the chevy trucks. I am curious about the numbers and date codes of the 68 and if anyone has an original 68 BB that they could share there casting numbers and date codes; I know alot of people don't care or think it matters on these trucks, but I m curious and would like to learn more on this.
1) Engine Block
2) Heads
3) Exhaust Manifolds
4) Intake Manifolds
I am basicaly verifying my numbers and curious about others
My block number on mine is:
TO305XG
which I believe to translate to being built in T = Tonawando NY (as all BB's)
on 0305 = March 5,
XG = 396ci-v8 BB 3spd Auto A.I.R 4bbl
The year then can be obtained from the back of the block;
3935440-S translates to be a 68-69 396 2 or 4 bolt main.
The heads I am not sure about I know for sure one was changed.
Exhaust Manifolds are :
Lt = 3909880 date coded L227 = (12/22/1967)
Rt = 3909879 date coded J67 = (10/6/1967)
I need to get my Intake # and casting date
I am also trying to find out if the 68 396 came with a 5 blade fan originally?
Any one that has any additional info would be appreciated...Thanks
68 SB 396
72 SB CHEYENNE 402
04 Silverado SS
chevys2die4 is offline   Reply With Quote
Old 11-29-2008, 12:46 AM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Original Big Block Engine Info?
I should be able to identify most of your casting numbers if that helps you. (Intake, carb, dist, etc...)
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is online now   Reply With Quote
