Old 11-28-2008, 10:13 PM   #1
Chris in Idaho
Suburban axles for truck?
I have an opportunity to get a 14BFF and a 8 lug 10 bolt front out of a suburban, and I'm wondering if they will bolt right up to a pickup. I know I'll have to shorten my driveshaft for the longer pinion, but what about spring perch locations? Are the springs the same width between pickups and suburbans?
Chris in Idaho is offline   Reply With Quote
Old 11-28-2008, 10:57 PM   #2
ak's-r-us
Re: Suburban axles for truck?
deleted
ak's-r-us is offline   Reply With Quote
Old 11-28-2008, 11:26 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
There was an extensive post on this about 2 weeks ago, did you try a search..
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-29-2008, 04:32 AM   #4
Chris in Idaho
Yes, I did. I searched for "suburban axle" and it brought up a lot of posts about about making dually suburbans and which axle to run, but nothing about the perch locations. Maybe you could give me better search terms that might lead me to the extensive post? I understand it's annoying to discuss the same topic multiple times...
Old 12-01-2008, 12:26 PM   #5
Chris in Idaho
If anybody else happened to be wondering the same thing, I went to the junkyard with a tape measure... Suburbans and 1/2 and 3/4 trucks have the same perch locations, it was roughly 42.5" but 1 ton trucks and a 5/4 ton CUCV I measured were narrower at 40". It looked like the spring hangers were different, and you could swap spring hangers to match whatever axle you found possibly easier than moving the perches on the axle.
So, yes the suburban axles will work in my short bed.
Old 12-01-2008, 12:26 PM   #6
Chris in Idaho
This was all referring to the rear axle, the fronts were all the same.
Old 12-01-2008, 02:23 PM   #7
vern350
like a rock
vern350's Avatar
good info....
vern350 is offline   Reply With Quote
