Old 11-29-2008, 12:07 AM   #1
NWD02
Lightbulb Steering column to gearbox, pics?
I need to see some pictures of the steering columns to the gearbox. Will the same piece work off a 3spd column and an automatic tilt?
NWD02 is offline   Reply With Quote
Old 11-29-2008, 12:37 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Steering column to gearbox, pics?
This is my auto non tilt column. Hope it helps.
I just realized don't have a complete photo after I redid my steering column.
s/t
Here's one after I painted everything.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Last edited by Sport/Truck; 11-29-2008 at 12:47 AM. Reason: added picture of painted column
Sport/Truck is offline   Reply With Quote
Old 11-29-2008, 12:41 AM   #3
NWD02
It's helping a little. One from in the cab would be a big help too. I'm trying to figure out what I'm missing to install the column.
Old 11-29-2008, 12:51 AM   #4
Sport/Truck
Sierra Grande Club
I don't have one in the cab. But it has only one clamp IIRC.
s/t
Old 11-29-2008, 01:24 AM   #5
NWD02
So inside the cab there's only one other mount right?
Old 11-29-2008, 01:58 AM   #6
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I thought they was 3 clamps inside 2 under the dash and 1 other closer to the cluster that clamps the rubber part of the colum I may be wrong it might just be 1 under the dash and one to hold the rubber ... But Who knows I Still haven't mouted mine Niether on that end, maybe I will do it tomorrow...
Subscribed to Thread JIK I'm wrong.....I might need this info too ...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 11-29-2008, 02:27 AM   #7
NWD02
There's the one on the firewall (strap around the column), the ring inside the firewall (under dash), one towards the top of the column under dash (i think) and the thin plate that is directly under the rubber near the gauge cluster...
Old 11-30-2008, 12:43 AM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
I just shortened my 72 column and there is one band clamp at the firewall under the master and one strap at the cluster.
dwcsr is offline   Reply With Quote
Old 11-30-2008, 08:58 AM   #9
70GMCer
70GMCer's Avatar
I use all the brackets from my 3spd manual to auto tilt swap.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-30-2008, 11:07 AM   #10
NWD02
Did you use the same shaft connecting the column to the gearbox?
Old 11-30-2008, 11:29 AM   #11
70GMCer
70GMCer's Avatar
No...the column shaft is totally different on a tilt.....The shaft that the rag joint connects to, I'm not sure if the tilt one is the same or not as my tilt was complete including both shafts. I just used the mounting brackets & rag joint from the manual column.
1997 GMC Sierra Ext
1965 Mustang
Old 11-30-2008, 11:53 AM   #12
NWD02
Ok, thanks, that helps a lot.
Old 12-01-2008, 12:55 AM   #13
NWD02
Ok, here's a little more information on what I'm doing. I'm trying to convert my 67 from 3spd to auto tilt. I took the truck apart roughly a year ago and trying to figure out the brackets and what goes where. I think I just figured out the upper bracket has the rubber squares on it where the brake and clutch pedals used to rest. I'm thinking it might be a different bracket for 68-72 since the e-brake changed. I've found the lower(outer firewall bracket. I have another piece that I think goes with the upper. It's flat partial rounded strip. Any help would greatly be appreciated.
Old 12-01-2008, 12:56 AM   #14
NWD02
70GMCER, do you have a picture of the upper bracket and how it's mounted? Thanks again.
Old 12-01-2008, 12:13 PM   #15
mbgmike
I wood make it out of wood. Sorry Nick
mbgmike is offline   Reply With Quote
