Old 11-29-2002, 02:16 AM   #1
Kiss My SS
Kiss My SS's Avatar
NP 205 questions
ok, here's the deal. My dad and I went for a test drive in the Jimmy tonight. We tested the four wheel drive for the first time and found that it is not working. It shifts into 4wheel hi and low and you can feel the gear reduction in low. The problem is that the front driveshaft isn't turning. It drives the rear wheels fine in 2 and 4 wheel. As much as I can figure, the front drive gear isn't engaging. Anyway, I figured I would check the level of lube in the t-case. Now there are two plugs on the back of the case. I assumed the top was to check the fluid level and the bottom was to drain the case. So I took out the top one and a lot of fluid came out. That seems strange. If the fluid level was supposed to be higher than the plug, then where do you fill it? I just copied the pictures from the magazine article about the 205 rebuild from and earlier post. Hopefully this might help me figure out what is wrong with my t-case. Also, what type of oil do you use in this case? Some have told me 90 weight gear oil where others have told me 30 weight. The stuff that came out looked more like gear oil. If you have any suggestions about any of these questions, I would be much appreciative. Thanks.
1972 GMC Jimmy 4x4
1985 Chevy Monte Carlo SS
1996 Saturn SC-2
1996 Ford Explorer XLT -Wife's rig
Kiss My SS is offline   Reply With Quote
Old 11-29-2002, 11:01 AM   #2
Beast388
Suburbans RULE!
Beast388's Avatar
How did you determine that the front driveshaft wasn't turning?
An easy test is to make sure the hubs are unlocked and the transfer case is in either 4hi and/or 4lo. With engine off and tranny in park, or clutch engaged, climb under the truck and see if the front driveshaft will turn. If it does then you have a problem.
I have always put 80w/90 gear oil in my NP205. That is what all of my book recommend, including the owners manual. And yes, the fluid level should be high enough so that you can stick a finger into the top hole and feel the fluid. Good Luck!
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 11-30-2002, 03:20 AM   #3
chevypete396
chevypete396's Avatar
Might just have a busted hub. Or it might just be your transfercase linkage.
I am not sure why alot of fluid came out of the top plug. It's not supose to if it was checked / filled on level ground. You are right, that top plug is where you check and fill the t-case. and the bottom one is the drain.
I had a situation once with the 205 and 4 speed on my 68 "making oil". The oil was passing from the tranny through the 4 speed adapter into the 205 causing it to over fill the transfercase and under fill the tranny. It caused the rear seal to blow out of the transfercase at the rear drive shaft on the hiway from the heat. Your Jimmy probobly has an auto tranny so I don't think that the adapter seal could be a problem in your case.
If you do have a standard tranny: On level ground, drian off the excess or fill it to the proper level. Check it in a few days then in a few weeks then months. Keep an eye on it and see if it over fills again.
Like said, use SAE 80/90wt "gear lube" for the 205 T-Case... Pete
1968 Chevy - 3/4 Ton - 4X4 - Longbed - 383ci - TH350 - NP205
Building the motor, painting the engine bay, rewireing everything...
(775)-527-1199 / ryanspeterson@msn.com
chevypete396 is offline   Reply With Quote
Old 11-30-2002, 05:32 PM   #4
mkmiller1
mkmiller1's Avatar
fluid
As far as too much fluid, I've heard of backing the rear wheels onto ramps then filling the transfer case full. this allows the fluid to run to the front of the case so you can put more in. I've mainly heard of this with NP203 transfers with part-time kits, but you never know.
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 12-01-2002, 02:04 AM   #5
Rod
An automatic can push tranny fluid into the transfer case also if there are bad seals.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-01-2002, 08:28 PM   #6
GMCJON
Don't know about the rest of you, but I don't find it a rareity to have excess oil come out of the fill/check plug on most any drivetrain components. I have checked more than my fair share of "boxes" on trucks, and I'd say about a third of the time excess oil comes out of the rearend, transfercase, or tranny. Even on new rigs this happens all of the time. I would not worry about it at all. I know that when I fill up my boxes, I quit pumpin in the 80/90w when some of the fluid comes out, and then insert the plug. Not once have I heard of it causing a problem. Anyway, my post kind of contradicts the rest of the reply's, so I dont know if it will help or just confuse the heck out of you.
Proud third owner of a 1967 GMC 4x4. Only 72,000 original miles and I am VERY proud to say my parents didn't buy it for me.
GMCJON is offline   Reply With Quote
Old 12-01-2002, 11:32 PM   #7
chevypete396
GMCJON...
I have seen over filling a lot as well but In SMALL amounts. The type of over filling your talking about probably causes very little or no problems. He didn't say "a little" he said "a lot of fluid came out" thats why I gave him the advise I did...
When it blew the real seal out of my transfer case on the highway, it was over filling by a lot from the tranny. Probably as full as it could get. When I pulled over to see where all the smoke and oil was coming from I couldn’t even touch the T-Case it was so hot. This type of over filling creates to much heat and can cause damage and a huge mess. I would caution anyone against backing the rear wheels onto ramps then filling the transfer case full with an NP205. Nothing can be gained by doing this.
ROD:
Thanks for your reply, I didn't know that. I thought the auto trannys were sealed better in the rear and the transfer case/ tranny adapter was a completely different type of design... Pete.
Old 12-03-2002, 08:19 AM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Question T-CASE
IF YOUR FRONT DRIVE IS NOT TURNING, THEN IT IS A MECHANICAL PROBLEM, NOT FLUID. CHECK YOUR LINKAGE, THEN YOU MIGHT HAVE TO PULL IT AND GO THROUGH IT. 4X4 HEAVEN 1-800-800-1679 HAS ALL THE PARTS.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 12-04-2002, 12:39 AM   #9
mkmiller1
mkmiller1's Avatar
thanks chevypete!
thanks for clearing that up on the transfer case. I DO NOT promote jacking up the rear wheels to get more fluid in the case. As you said, nothing would be gained.
Thanks,
Matthew
Old 12-29-2002, 01:46 AM   #10
Duallie
Duallie's Avatar
Drain it and replace the fluid. It could've been driven through a creek or something and filled with water. The water would go to the bottom and displace the gearoil upward, and when you drained it through the top plug, you coulda just let the oil out and left the water.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 12-29-2002, 11:30 AM   #11
OLDCHEV4X4
OLDCHEV4X4's Avatar
Kissmyss...is it auto or manual?
Are the hubs engaging?
Check the drivshaft like posted earlier.
Only fill it with 90w gear lube to the level of the top plug
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 01-07-2003, 10:20 AM   #12
ckhd
ckhd's Avatar
Definitely check the linkage. There are two rails on the 205, one that controls the high/neutral/low, and one that controls when the front driveshaft turns. Crawl up under, and have someone cycle the shifter through it's range. Make sure both shafts move clear in and clear out. The swivel points in the shift linkage tend to wear out and not move the rails as far as intended.
Overfilling shouldn't make the t-case not shift into 4 wheel drive.
As far as I can see, overfilling is from one of the three things mentioned:
1) someone putting too much fluid in.
2) water in the t-case.
3) leaky transmission seal.
In any case, I'd drain the fluid, and put fresh 80w-90 in. Check it in a couple of weeks to see if maybe it's the tranny pushing fluid in.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
