Old 11-29-2008, 12:55 PM   #1
HOTFUN
HOTFUN's Avatar
67 K10 swb stepside production numbers?
I see where some of you have GM total model year production numbers for your truck model?
Where are you getting those production unit total numbers? My truck, I am restoring is a true 1967 V8 4wd model KE10704 and I know this V8 shortbox 4x4 has to be a low production unit didn't know GM in the US documented these model year break downs?
My VIN is KE147Z130***
Thanks, Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 11-29-2008, 12:57 PM   #2
msgross
msgross's Avatar
Re: 67 K10 swb stepside production numbers?
I've seen the numbers... yours is like 1,000 or something...
be right back with accurate #'s.
here's the link
http://67-72chevytrucks.com/vboard/s...d.php?t=104816
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-29-2008, 12:58 PM   #3
msgross
msgross's Avatar
here you go... from this board thank to John Fabris
Here Goes!!
1967
1/2-Ton Commercial - Model C/Series 10 - 115-in. w.b
MODEL BODY TYPE PRICE WEIGHT PROD.TOTAL
CS10703 Chassis & Cab 2223 2914 2790
CS10734 Fleetside 6.5ft 2371 3333 43940
CS10704 Step-Side 6.5ft 2333 3255 45606
1/2-Ton Commercial - Model C/Series 10 - 127-in. w.b
CS10903 Chassis & Cab - - 39
CS10934 Fleetside 8ft 2408 3440 165973
CS10904 Step-Side 8ft 2371 3345 19969
CS10905 Panel 2742 3502 3827
CS10906 Suburban 2986 3670 5164
1/2-Ton Commercial 4x4 - Model K/Series 10 - 115-in. w.b
KS10703 Chassis & Cab 2903 - 32
KS10734 Fleetside 6.5ft 3051 - 1046
KS10704 Step-Side 6.5ft 3013 - 1229
1/2-Ton Commercial 4x4 - Model K/Series 10 - 127-in. w.b
KS10903 Chassis & Cab - - 41
KS10934 Fleetside 8ft 3088 - 2715
KS10904 Step-Side 8ft 3051 - 500
KS10905 Panel 3422 - 30
KS10906 Suburban 3666 3670 166
3/4-Ton Commercial - Model C/Series 20 - 127-in. w.b
CS20903 Chassis & Cab 2403 3346 6320
CS20934 Fleetside 8ft 2550 3848 50413
CS20904 Step-Side 8ft 2513 3753 785
CS20909 Stake 2606 3973 1415
CS20905 Panel 2884 3917 940
CS20906 Suburban 3170 4093 709
3/4-Ton Commercial 4x4 - Model C/Series 20 - 127-in. w.b
KS10903 Chassis & Cab 3083 - 498
KS10934 Fleetside 8ft 3230 - 2773
KS10904 Step-Side 8ft 3193 - -
KS10905 Panel 3286 - 8
KS10906 Suburban 3850 - 120
Long-Horn Pickup
KS21034 Fleetside 8.5ft - - -
1-Ton Commercial - Model C/Series 30 - 133-in. w.b.
CS31003 Chassis & Cab 2561 3556 11304
CS31034 FleetSide 8.5ft 2755 - -
CS31004 Step-Side 9ft 2695 3995 4026
CS30909 Stake 2875 4390 3236
The Garage:
Old 11-29-2008, 01:28 PM   #4
HOTFUN
HOTFUN's Avatar
Mike
Very interesting link. There is quite a discrepancy in the listings. The vin K is of course 4wd versus C being 2 WD but the second letter E is V8 and C is a 6 cylinder. So in that listing all the 67 models are listed as 6 cylinder models and the 68 is listing mostly V8 only. And it goes the same for the 69 and 70's there. Do you suppose they are not broke down between 6 and 8 cylinder models or could it be that it should read 67 and 68 models both 6 and 8?
This truck I have is a factory built short frame never been cut down and the VIN and the truck installation is absolutely a factory V8 installation.
I know they are super rare in the shortbox and even more rare in a V8 short that year. I couldn't believe I would ever in my life find this truck. The original engine was replaced with later 307 but the rest of the drive train is bone stock original right down to the old spicer locking hubs and the 3 speed column shifter. In my frame up going on now, I am upgrading to a 205 /turbo 350 automatic behind a numbers matching 67 pickup 327. I also plan to go with a 72 disk brake front axle assembly. Thanks so much for the info. I have to believe that the 1000 units would be believeable anyway.
Mark
'72 GMC K2500 4x4
Old 11-29-2008, 01:55 PM   #5
msgross
msgross's Avatar
Mine says Model=KE10734 in the options window and my VIN starts KE as well (327 engine) What does your gloveboax door say for Model #.
those production numbers might be 6 cylinder for 67... i'll keep searching
The Garage:
Old 11-29-2008, 02:05 PM   #6
msgross
msgross's Avatar
more info
1967-1972 VIN Number Codes
Example: CE149J 100001
Chassis Designation (1st digit)
C= 4x2
K= 4x4
Engine Deisgnation (2nd digit)
E = V-8 Gas
S = Six Cylinder Gas
GVW Range (3rd Digit)
1 = 1/2 Ton
2 = 3/4 Ton
3 = 1 Ton
Model Code (4th Digit)
4 = Pickup with Cab and Bed
Model Year (5th Digit)
7 = 1967
8 = 1968
9 = 1969
0 = 1970
1 = 1971
2 = 1972
Assembly Plant
A = Atlanta
B = Baltimore
F = Flint
J = Janesville
N = Norwood
P = Pontiac
S = St. Louis
T = Tarrytown
Z = Fremont
1 = Oshawa
Vehicle Serial Number
100001 = 1st Unit Built
1967-1972 Model Number Codes
(The Model Number is located on the inside of the glove box door.)
Example: C E 1 09 9 34 J 100001
C = 4x2
K = 4x4
P = Forward Control
E = V-8 Gas
1 = 1/2 Ton
2 = 3/4 Ton
3 = 1 Ton
Cab To Axle Dimension (4th Digit)
07 = 42"-47"
09 = 54"-59"
10 = 60"-65"
12 = 72"-77"
13 = 78"-83"
14 = 84"-89"
15 = 90"-95"
7 - 1967
8 - 1968
9 - 1969
0 - 1970
1 - 1971
2 - 1972
Body and Brake (6th Digit)
02 = Flat Face Cowl
03 = Cab
04 = Stepside Pickup
05 = Panel
06 = Suburban
09 = Cab, Platform, and Stake Rack
12 = Windshield Cowl
16 = Suburban (Tail and Liftgate)
26 = Custom Suburban (Panel Rear Doors)
34 = Fleetside Pickup
35 = Foward Control (Square Front)
36 = Deluxe Suburban (Panel Rear Doors)
42 = Forward Control Chassis
45 = Forward Control Panel (Round Front)
Assembly Plant
A = Atlanta
B = Baltimore
F = Flint
J = Janesville
N = Norwood
P = Pontiac (GM Truck)
S = St. Louis
T = Tarrytown
Z = Fremont
1 = Oshawa, Ont., Can.
The Garage:
Old 11-29-2008, 11:14 PM   #7
HOTFUN
HOTFUN's Avatar
Mike
A model code KE10734 is used all years as a 8 cylinder, 4WD, fleetside swb pickup and mine has a code on the pass side firewall barely visible and also listed as the model# on the title as KE10704 K= 4wd, E= 8 cylinder, 107= swb and 04= with stepside box. My original glove box label was long gone but the original VIN tag still factory attached to the truck is KE147Z130xxx with 5000 lbs rating. This vin#would be a 4wd, V8, pickup body, 1967, and Fremont, California built. 30,000 and some built unit off the Fremont plant line in late 1966 or early 1967.
I would still be interested in any documentation as to how many Chevrolet built of the KE10704 models for 1967.
Thanks for the info. Mark
'72 GMC K2500 4x4
Old 11-29-2008, 11:27 PM   #8
msgross
msgross's Avatar
I found those same numbers in a few spots on the internet... all quoted from a book. All other years they posted like numbers in the KE model range... I would think they it covered both...
I know it's less than 2,000 4wds ever builts like that... I would use the 1229 number... not many of them out there anymore.
The Garage:
Old 11-30-2008, 11:38 AM   #9
HOTFUN
HOTFUN's Avatar
I have most everything saved up for this as it was originally white with blue interior but I plan to build it black with red interior CST and buddy buckets. I have a mint total dry rust free 67 red interior cab to compliment the build.
Thanks Mike, for all your trouble posting those numbers and there will be more pictures as this comes together in the next 6 months. I've been following your sweet 68 project.
Mark
'72 GMC K2500 4x4
Old 11-30-2008, 11:42 AM   #10
HOTFUN
HOTFUN's Avatar
Picture didnt load try here again.
'72 GMC K2500 4x4
Old 11-30-2008, 01:49 PM   #11
msgross
msgross's Avatar
That's a nice custom there...thanks..
The Garage:
