11-29-2008, 01:37 PM | #1 |
6 cyl truck tach cluster
Kind of rare--an original truck tach cluster for a 6 cylinder truck---originally had air pressure too. I had to replace the bezel and the lense. This tach cluster has the rear metal for a air pressure or vac gauge so you can upgrade this too which is kind of nice. 8 cyl tach dash clusters are pretty common and available in aftermarket too but an original 6 cylinder~~~~~yep, kind of hard to find. Probably only available on larger trucks so here is your opportunity 6 banger guys~~~. $350. shipped US lower 48 mainland~~. Huck
11-29-2008, 04:10 PM | #2 |
Re: 6 cyl truck tach cluster
that looks like a 8cyl tach to me but i could be wrong
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
11-29-2008, 05:13 PM | #3 |
Resident Curmudgeon
Would like to be first in line.
Question, does it come with the harness and can you tell me if it came out of a truck with a striaght 6 versus the V6?
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-29-2008, 08:07 PM | #4 |
CPNE--does not have the harness with it but i will make one up for you if you need it. It came out of a farm truck--don't know if it was a straight 6 or V6---should not make any difference. And yes, it is an original 6 cyl tach and you can see the factory stamping on the rear cover of the tach. Huck
11-29-2008, 08:13 PM | #5 |
See factory stamp on rear~~
11-29-2008, 08:22 PM | #6 |
Roadtrip!
There is no difference in a 6 cyl or 8 cyl tach from the front. If it only goes to 4000 rpms it is a mechanical drive diesel tach which looks similar. The stamp on back tells you what it is for.
I am also unaware if there is a difference between V-6 or I-6 tachs? Huck, nice set-up. TTT for ya.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
11-29-2008, 08:49 PM | #7 |
"GO DAWGS"
Eric is correct, the 6 and 8 cyl. look the same and the 4k diesel tachs are cable driven and hook up just like a speedometer does.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
11-29-2008, 09:33 PM | #8 |
Put me second after CPNE.
11-29-2008, 10:15 PM | #9 |
How does a tachometer know if the signal is from a V8 or a 6 cylinder. Just curious!
The biggest problem people have, is other people Thou shalt be cool and not hassle Be a site supporter. The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
11-29-2008, 10:42 PM | #10 |
A tachometer doesn't know what it is hooked up to--you have to tell it! It will respond by indicating how many revolutions per minute the signal is sending. For 4,6,8 cylinder engines, it will simple be designed to divide the number of signals by the number of cylinders and indicate via a magnetic pulse to a indicator which will correspond to the gauge marking. What sometimes causes issues is the length of the pulse wave such as an HEI verses a points ignition system. These old tachs are not very accurate compared to current technology which is solid state verses electro-mechanical. Huck
11-29-2008, 11:52 PM | #11 |
i have seen 6 banger tachs with a white line on the gauge face and the needle looked diffrent that is why i thought that it was diffrent what tach did i see
11-29-2008, 11:54 PM | #12 |
hoorah. Well done. and thank You Huck.
Larry
11-30-2008, 09:12 AM | #13 |
CPNE===you're #1
LooseCannon===you're #2 will send CPNE a PM with 24 hour response required--Huck |
11-30-2008, 10:34 AM | #14 |
Resident Curmudgeon
PM received. I'll confirm my intentions by this evening. Thanks
11-30-2008, 09:03 PM | #15 |
Resident Curmudgeon
Sold, Pending Paypal info from Huck, PM sent
12-01-2008, 09:32 AM | #16 |
SOLD and thank you all for your timely information re the 6-8cyl tach confusion. Perhaps in the future some will refer to this as a information page on the differences. Huck
12-01-2008, 12:02 PM | #17 |
Member #1049
Just thought I would post an FYI...
The part number for the V8 tach is: 6468226, And for the 6cyl: 6468321. |
12-01-2008, 12:34 PM | #18 |
Dam how did I miss that one!
Douh....
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
12-01-2008, 03:57 PM | #19 |
Tot Roddin'
That's what I was thinking Mt Man Chad...
Nice score CPNE!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
