Old 11-29-2002, 11:20 AM   #1
Terry'sToy
Question Does anyone have pics of shocks relocated on truck?
just curious as I'm about to relocate mine outside the frame to help stop the sway I'm getting from my camper. It's either do this or use air bags but I don't know of a company that makes bags to fit anymore. Airlift stopped making the ones that went in the coil for our trucks.
Terry.
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's
Terry'sToy is offline   Reply With Quote
Old 11-29-2002, 12:02 PM   #2
vfrdude
vfrdude's Avatar
Have you installed a rear sway bar yet???? That would be the way to go - I don't think reloacting the shocks are going to get you anything as far as sway...
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
Old 11-29-2002, 12:44 PM   #3
hanssolo
hanssolo's Avatar
I've often thought about welding on a 2nd set of shock mounts on just for a smoother ride.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 11-29-2002, 04:12 PM   #4
Terry'sToy
I have thought of doing a rear swaybar, but for some reason I thought they weren't that great on coil rear trucks. I was thinking of relocating the shocks to the outside of the frame, thinking that it would control the sway better than where they are on the inside of the frame on that odd angle.
Old 11-29-2002, 04:19 PM   #5
wnc mountain
More hobbies than money!
wnc mountain's Avatar
I don't think you would see much difference moving the shocks. A sway bar would be the way to go.
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
Old 11-30-2002, 12:54 AM   #6
Jesse 67 c-10
Jesse 67 c-10's Avatar
Moving the shocks out would definatly help! think of trying to hold up a top heavy weight with your hands close together, now move them to the outer extremes of the weight, much easier to keep balanced! for the best handling the shocks should be straight up and down to the axle movement and as close to the wheels as possible. Things to think about though, you need to make sure your shocks have the right amount of travel so they don't bottom out, also adjustable ones would be great since most shocks are tuned somewhat to the original application, changing the position would increase the effect the shocks have on the axle movement, could end up with a harsh ride if the shocks are too stiff, also they won't last long with a lot of road spray in the wrong position. A setup like this may keep you from needing a sway bar, a lot lighter than a sway bar too! and if you still want more swaybar mounts could be incorporated into your shock mounts somehow. Go for it! I know I will someday when I have time and money!
Good Luck
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 11-30-2002, 01:00 AM   #7
Alexis
Member since 2000
Alexis's Avatar
this might help, Drag bags
http://www.jegs.com/cgi-bin/ncommerc...43&prmenbr=361
Alexis is offline   Reply With Quote
Old 11-30-2002, 02:27 AM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
Shocks really don't handle the weight though..... that's what the springs do. Shocks just control the rebound of the spring. I also don't think relocating them would help.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 11-30-2002, 09:56 AM   #9
hanssolo
hanssolo's Avatar
Rear sway bars are almost a must on coil suspension. I'm suprised the factory did'nt put one on yours. Leafs bend in a line but coils can rotate to a certain degree.
Old 12-01-2002, 11:32 AM   #10
Terry'sToy
Thanks again for all the answers. Maybe I'll look into a sway bar, or I'll get inventive and let ya know how it goes.
Terry
