Old 11-30-2008, 02:17 AM   #1
eric67m
eric67m's Avatar
gear noise - sm465/np205
On my 67 K10 LWB, which has a sm465 4speed and a np205 transfer case I recently swapped out my transmission and transfer case because my old transmission output and coupling had lots of slop. I have been driving with the "new" ones and have found a few things that are different than the old set.
1. There seems to be more "gear" noise in 2nd and 3rd than I remember my old transmission having. This noise goes away in 4th.
2. It is often times hard to downshift into 3rd or 2nd. Worse when engine is colder but sometimes when warmed up.
3. I still have a little bit of gear slop noise when I get off of the throttle. I think that this may be in my rear drive shaft (front not installed currently).
I definatly had problem #3 with my old set and that is sooooo much better. Do other people have these problems? I am thinking there is something slightly wrong in the transmission, possibly syncros?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 11-30-2008, 09:55 AM   #2
68,69 K20
They call me the Breeze...
68,69 K20's Avatar
Re: gear noise - sm465/np205
Have you checked the gear oil level in the trans?
Mike
69 K20
"Beer is proof God loves us and wants us to be happy"....Ben Franklin
68,69 K20 is offline   Reply With Quote
Old 11-30-2008, 08:51 PM   #3
eric67m
eric67m's Avatar
I checked it a few miles after swapping it in and it seemed ok. I have driven it probably another 50 miles since then. I should probably check it again.
I have other bigger problems. Due to a really rusty floor and gravity, my cab mount bolts punctured my gas tank.
Old 12-01-2008, 01:01 PM   #4
1969K10
1969K10's Avatar
#1, IDK
#2, my guess is the synchro's are going out. Mine is almost impossiblel to downshift into 2nd
#3, is probably wear between the tranny & x-fer coupler, or a U-joint about ready to grenade.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 12-05-2008, 11:51 PM   #5
Chris in Idaho
Do you double clutch or just try to push it in? SM465's have heavy rotating parts...
Chris in Idaho is offline   Reply With Quote
Old 12-06-2008, 09:34 AM   #6
eric67m
eric67m's Avatar
I generally just try to shove it in. I have tried to double clutch or rev match. It shifts ok 50% of the time when cold. But when it doesnt want to shift you almost have to stop to get it into 3rd or 2nd.
Old 12-13-2008, 11:10 PM   #7
JAKES 68GMC
Aluminum slot wheels rule...
I have all the same symptoms as you do in my 68...all i can say is they are just old truck quirks/noises. Mine howls in 3rd pretty good and sometimes clunks when u let off the gas, due to play in the transfer case, but I wouldn't worry about it. I've driven mine for about 4000 miles like that with no problems yet.
JAKES 68GMC is offline   Reply With Quote
