Old member
Ok, I know alot of you don't like the clear lens, but I added red to mine. What do you think. I glued a trailer lens inside of the brake housing under the clear lens.
![]() It fit perfect with no cutting, I was scared I would have to cut it and then I would have messed it up. ![]() ------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels www.geocities.com/chevy71tpi/main.html www.picturetrail.com/Andy4639
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I think it looks killer,,mind if I copy idea?
68 chevelle(garage queen) 72 cheyenne super(driver) Owasso, Oklahoma |
Old member
That's why I posted it. I figured there would be some more people interested in do it. I used goop glue, that stuff will hold anything, you can buy it at w/mart and lowes.I think the parts store may have it also. I used the little red square lens out of the replacement packs you buy at w/mart. The pack has the round,amber, and this one in it.
How do you change the bulb?
------------------ http://hometown.aol.com/racedvl/racedvl69index.html Woodstock,IL.northwest of Chicago It's not what you buy, it's what you build!! I did not climb to the top of the food chain, to become a vegetarian. For some pics of my truck. |
Thats sharp.
------------------ 71 GMC 2500 Custom Camper 71 GMC Suburban 1500 Super Custom 71 Chevrolet 1500 Donor http://www.able-bravo.com
71 GMC 1500 LWB |
whats that sticker say on your tailgate? _.0 liter H.O. ??
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
Old member
REPLY 1 ABOUT BULBS.
Not worried about the bulbs, I'll just pry it off when I need to. I put the led bulbs in so it want get that hot and they are suppose to last a long time. Reply 2 ABOUT Sticker When I put the TPI in my truck I wanted a emblem to signify a 5.0 motor. I ordered the ones from Chevy and that's what they sent. 5.0 liter HO . I didn't like it for the side by the Custome Deluxe emblem, so I ordered the 5.0 (mustang) I know, it's a ford emblem, but what can I say it looks alot better than the one Chevy sent me. It matches up pretty good with the C/D emblem as well, same size, and it's chrome stick on. ------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels <A HREF="http://www.geocities.com/chevy71tpi/main.html]www.geocities.com/chevy71tpi/main.html[/URL" TARGET=_blank> [URL=http://www.picturetrail.com/Andy4639]www.picturetrail.com/Andy4639</A> [This message has been edited by Andy4639 (edited May 11, 2002).]
I think it looks great
![]() I may have to borrow that idea as well ![]() But I do have one question.... Are they bright enough in daylight??? Most of the LED bulbs I have seen that fit under a lens are kinda on the dim side.
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
