Old 11-30-2008, 02:42 PM   #1
BrianZ88chevyS
BrianZ88chevyS's Avatar
Question automatic tranny- Shift linkage / Dash Needle
hey ,, does n e one know how the Needle in the dash is connected to the shifter on the column,, when i shift fr P to D or R ,, the Needle in the dash doesnt move,,, just stays on P ???
BrianZ88chevyS is offline   Reply With Quote
Old 11-30-2008, 04:03 PM   #2
ChevyTech
Re: automatic tranny- Shift linkage / Dash Needle
It is attached to the steering column lower housing “shroud” aka (gearshift bowl) with a cable.
The cables break.
Old 11-30-2008, 04:31 PM   #3
BrianZ88chevyS
Question Re: automatic tranny- Shift linkage / Dash Needle
is that down by the Hi-beam switch ?? how hard is it to change ???
Old 11-30-2008, 05:09 PM   #4
ChevyTech
Not that far down but connects to the big round outside shell around the lower column that turns when the shifter is moved, just up the column from where the high beam switch is.
The shift indicator cable connects to the driver’s side of the column and the high beam switch is on the passenger side.
Not bad.
Just make sure the cable did not cut a deep grove in the plastic by the indicator which can cause the cable to get caught in the grove and break.
Old 12-02-2008, 07:07 AM   #5
BrianZ88chevyS
ok ,,,,,,, i took the gauge cluster out and there is no cable there at all ,, soo i'll have to pick one up,,,,,\
n e one on here have a pic of what it all looks like ??,,, been searching the Net and cant find n e thing on that cable ,,,,,,,
Old 12-02-2008, 10:15 PM   #6
ChevyTech
It is not a 1988-1998 truck photo but the second photo down at this site shows how the cable attaches to the column housing/shroud.
Photo source:
http://tech.oldsgmail.com/eint_flash.html
Old 12-02-2008, 10:26 PM   #7
BrianZ88chevyS
ok ,, THANX Chevytech ,,, dont look to hard to hook up lol,, Dont imagin they cost tooo much ,,,
