Old 11-30-2008, 04:04 PM   #1
pat123
Pat
pat123's Avatar
Is this a common place for cabs to go?
This is the only place on the roof or the cab that has rust. Do they rust in this area or is my cab "no good" ??
Thanks Pat
pat123 is offline   Reply With Quote
Old 11-30-2008, 04:18 PM   #2
Wilson_
Wilson_'s Avatar
Re: Is this a common place for cabs to go?
Mine is the same way.
But on both sides.
Wilson_ is offline   Reply With Quote
Old 11-30-2008, 04:21 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Whats that brown stuff?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-30-2008, 05:08 PM   #4
watahyahknow
watahyahknow's Avatar
i have an 86 thats rusted all the way round , its the exact spot the rubber from the door hits
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-30-2008, 05:46 PM   #5
pat123
Pat
pat123's Avatar
Brown stuffs rust
Old 11-30-2008, 05:59 PM   #6
463
463's Avatar
Pat what happened is your drip seal in the drip edge (roof to cab seal ) is no longer sealing the water out of t he cab. the seal must be removed the rust repaired resealed with drip check or a seal of your choice and the repainted. here is a link with picks. http://67-72chevytrucks.com/vboard/s...d.php?t=276071
Trueman
463 is offline   Reply With Quote
Old 11-30-2008, 06:07 PM   #7
1956cameo
1956cameo's Avatar
My 70 has the same rust. Actually mine is much worse because I lived on an Island along the Texas coast for about 5 years. I am currently fixing it. Not really hard to do if you have basic fabricating and welding skills. Just take your time.
1956cameo is offline   Reply With Quote
Old 11-30-2008, 06:31 PM   #8
pat123
Pat
pat123's Avatar
so if it went their could it be worse between the roof and ceiling?
Like i said before thats the only place its rusted on the roof
Old 11-30-2008, 06:43 PM   #9
1956cameo
1956cameo's Avatar
I wont lie to you. If it is rusted there it could have weak spots in other area's and just haven't gone all the way thru. I cut alot of spots of my rooftop out which allowed me to see what was lurking between the layers. Fortunately it wasn't too bad. It also allowed me to spray rust converter in the entire space between the roof and the cab cieling. I would take a fairly sharp screw driver and moderately tap all along the top of the cabs roof, the cap cieling, and above the windshield. If everything is strong enough that the screwdriver doesn't go thru than you are fine. If the screw driver goes thru than that is a weak spot and the area needs to be cut out and patched.
Old 11-30-2008, 07:01 PM   #10
jwn1975
No good, find a better one. Dont waste your time
jwn1975 is offline   Reply With Quote
Old 11-30-2008, 07:12 PM   #11
pat123
Pat
pat123's Avatar
If everyone who had a rusted cab did that then we wouldn't have anymore left.
Old 11-30-2008, 07:18 PM   #12
heavy71chevy
heavy71chevy's Avatar
X@ man...thats how I feel about it..kinda like cutting a trucks head off but thats just my opinion
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 12-02-2008, 03:02 PM   #13
1956cameo
1956cameo's Avatar
I wonder the same thing. Where do all of these flawless cabs keep coming from, where a cab with even the slightest rust needs to be junked?
Old 12-02-2008, 03:30 PM   #14
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
The guy is asking for repair advice. Not a silly opinion. If that is the only rust on the cab then it would be considered darn near mint to someone trying to restore one of our trucks. I say patch it and keep the build going.
Old 12-02-2008, 05:40 PM   #15
69ROTROD
I thought a cab was good as long as when you slammed the door stuff didn't fall off.
1972 C/10!!!!!!!!!!!!!!!!!! NEW ADDITION!!
1969 C/10 LWB (Gone to greener pastures)
2006 Cadillac SRX
http://67-72chevytrucks.com/vboard/s...d.php?t=303768
69ROTROD is offline   Reply With Quote
Old 12-02-2008, 08:07 PM   #16
heavy71chevy
"Dixie Destroyer"
71 C10 LWB Fleet
Old 12-02-2008, 08:51 PM   #17
67sss
67sss's Avatar
here's a BAD cab, that's going away.
FIX IT!
67sss is offline   Reply With Quote
Old 12-02-2008, 10:38 PM   #18
watahyahknow
wheres the bondo i make it look like new in no time
Old 12-03-2008, 12:04 AM   #19
pat123
Pat
pat123's Avatar
sure a little bondo can make that cab look like new lol
