Old 11-30-2008, 06:44 PM   #1
powerbench
powerbench's Avatar
Long tube headers on a 4/6 drop
Anybody running long tube(headman) headers on their lowered trucks.How much clearance, do you have if any.....any one got some pics...ps runnig 15 inch ralleys with 235 /60/15...Would rather find out now before i spend any money having these headers ceramic coated. Thanks
powerbench is offline   Reply With Quote
Old 11-30-2008, 07:05 PM   #2
jwn1975
Re: Long tube headers on a 4/6 drop
My 70 swb is dropped at least that. Its LOW with static drop. I have long tube hooker super comps. They rub in and out or the driveway and on some parking lot exits. Just the flanges so far but its annoying. I seem to hit/rub thh swaybar brackets more often though. Its ok but i would try and buy short tube headers before i spend the money on ceramic coating. Ill try and get you a pic.
jwn1975 is offline   Reply With Quote
Old 11-30-2008, 07:12 PM   #3
powerbench
powerbench's Avatar
thanks....i bought the sway bar brackets from ece...but i'am kinda worried about knocking the headers off ,going over train tracks and stuff....the roads aren't to bad..
Old 11-30-2008, 08:17 PM   #4
jwn1975
I can go down the road pretty easy and hit bumps at speed and not have a problem. I hit my sway bar bracket about 4-1 over my heders. I dont drive it daily though. People behind me get kinda mad when i slow to turn into a gas station or store front. I just give em a little blip of the old big block and a tire chirp. Like ramone on the movie cars said "low and slow"
Old 08-20-2009, 05:07 PM   #5
Orange77
Orange77's Avatar
yea i have hookers too im wondering the same thing before i go and spend the money on the drop kit
Orange77 is offline   Reply With Quote
Old 08-20-2009, 09:28 PM   #6
69gmcshorty
69gmcshorty's Avatar
i HAD hedman lond tube headers on mine and the flange rubbed on everything. speed bumps, parkinlot exits, my driveway. and almost completely closed off the bottom tube that was closest to the ground on who knows what. I just recently got shorties and ran everything up in the frame. good luck
1969 gmc swb 5/7ish drop, 350/th400, 20x8.5 F.20x10" R
69gmcshorty is offline   Reply With Quote
Old 08-21-2009, 07:24 AM   #7
68Stepbed
68Stepbed's Avatar
I've got a 3.5/5 drop with Hedman long tubes. I've had no issues with hitting or rubbing anything yet. I just know they hang down, so I take it easy over speed bumps, potholes, etc.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-21-2009, 08:08 AM   #8
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
I'm really surprised by the two rubbing posts. I have a 5/7 drop and I have a country mile of room. I have never rubbed on anything. I think if a driveway is pitched enough, they might rub. When I get on my hands and knees and look under, tons of space. My exhaust is also ran under the frame and not through it. I guess it might be important to add though that I have some fairly good size tires up front.
prostreetC-10 is offline   Reply With Quote
Old 08-21-2009, 09:57 AM   #9
big_al_71
big_al_71's Avatar
I aldo have a 4/6 drop with doug thorley long tube headers and there is a ton of space under there and my exhaust is also under de frame....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-21-2009, 05:38 PM   #10
There was a time when about all lowered trucks ran full length headers.That`s all there was.anything shorter compromises the gain of headers over manifolds.I have regular headers for my static 4/6 truck I`m building.
Old 08-21-2009, 06:09 PM   #11
Ben IV
Im running thorely tri-y's with about a 5/6 Havent ever scraped the headers but have the flowmasters and pipes, especially putting it on a trailer even with a dovetail. I think it allso depends on if its a short or long wheel base.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 08-21-2009, 06:12 PM   #12
Ben IV
Just thought it may depend on if your using v8 mounts or 6 mounts mine is in the 6 position (dident know there was a difference at the time).
69 GMC panel truck
Old 08-22-2009, 12:34 AM   #13
69gmcshorty
you can see in my sig. my specs on the truck. here are a few pics of my long tubes that i took off. The p/o lived on a gravel road and maybe he drove like a fool but i needed to replace them.
Old 09-10-2009, 02:52 PM   #14
Orange77
Orange77's Avatar
so i should be fine with a 4/6? i have a swb 77 chevy c10 with 17s 265s i believe with hooker longtubes.
